Old 08-18-2020, 01:18 PM
Default Is it worth the trouble?
I have a bag of polymeric sand from Home Despot which I planned to fill the cracks in my paving slabs with. Supposed to harden when wet.
When I opened the bag it was soaking wet. I guess that their idea of storing it outdoors is not too good.
So I am wondering if it is worth the effort, when I give them their sand back, to get another bag, maybe from Lowes, if it is dry. Or just spray the cracks with weed killer.
If you have used this stuff, is it any good, or just high priced sand?
Old 08-18-2020, 01:25 PM
astronut's Avatar
astronut astronut is offline
Sorry Gerry I have never heard of or have any knowledge of the stuff. Hopefully someone else does. I am just curious though. If it is supposed to harden when wet, why was it not hard/solid in the bag when it was wet?
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 08-18-2020, 02:04 PM
It’s usually used on interlocking brick, apply dry, spread it around with a broom, and then run over it with a vibrating plate packer. As it works it’s way into the joints sweep more around til the joints are full. Then sweep the excess off, and wet it.
Some worked better than others, it’s basically adhesive applied the the sand.
If it’s wet already it would be a PITA to work with.
Old 08-18-2020, 02:22 PM
This one opinion.
Old 08-18-2020, 02:54 PM
Maybe because it is a shitty product. I did find a few lumps of hardened sand in the bag but 90% of it was just wet sand.
Why yes it was, so I stopped and want to do a re-think.
This one opinion.
This tells me as I suspected, I am wasting my time on this crap. I thought there was too much magic involved. I think a dose of Roundup or Curtail would be faster and better.
Thanks for the input, guys.
Old 08-18-2020, 03:52 PM
kbs2244 kbs2244 is offline
return it as defective foe cash refund
someone just thought it was sand and put it outdoors
the dept mngr will get dinged for it and next time it will be put indoors
Old 08-18-2020, 06:55 PM
460 Delta's Avatar
460 Delta 460 Delta is offline
Maybe just make your own LSM, low strength mortar, with some clean sand and a shovel full of Portland cement? How wide are the spaces around the pavers?
Perfection is the enemy of good enough.
Old 08-18-2020, 07:36 PM
1/8 to 3/16" gaps.
The pavers are 24 x 30"
Old 08-18-2020, 09:46 PM
I used it when I made the parking area for daughter in VA . After quite a few years there are some places the weeds do come in but I didn't have any vibrator to keep working more in the cracks, just kept brooming it. If done right I think it probably does work for a long time. What a "long" time is, may well depend on a particular persons idea. :-)
...lew...
Old 08-19-2020, 04:10 AM
460 Delta's Avatar
1/8 to 3/16" gaps.
Ah, I see, that's pretty tight as far as gaps. Probably use Roundup, then some clean sand swept in and call it done.
