Rest In Peace Cutter
Old 01-12-2020, 04:54 PM
Originally Posted by gimpyrobb View Post
I have a few of those combo pulleys.
Let me know what size yours is and I'll dig through my stash.
Will do it's hard to get good measurements due to how buggered up this thing is. But, here is what I came up with.
Small Pulley O.D. 3-9/16"
Large Pulley O.D. 5-3/4"
Outer Pulley Flange to Outer Pulley Flange 5-3/4"
Crank Bore 1"
Old 01-13-2020, 11:29 AM
gimpyrobb's Avatar
I'll dig through some pars tomorrow and let you know.
Old 01-13-2020, 07:53 PM
Originally Posted by Whitetrash View Post
Uh, no King Kong thoroughly destroyed this one. Getting it to run remotely true and balanced as in vibration free ain't happening without way more time than it's worth. New ones seem to run around $45 if I can pin down which one I need.
I have to say I've put alot of miles on ones that looked worse.
In the local Princess auto they have weld on sheet steel pulleys and a selection of hubs with common registers and diameters.
You have the hub, and you need some tin pulleys to weld onto it.
Old 01-13-2020, 09:46 PM
If you find 424 stamped on it. It's the right one Factory part # 756-0424 They made a change at some point and new # is 756-0631 it uses a separate spacer on the top side. I assume it would be marked 631
Old 01-15-2020, 12:45 AM
Ain't sure yet I have to figure out how to hang the Big Block chebbie off the back to run the hydraulic pump for the blower.
No problem to hang that BBC all ya need is a stick welder and some 1/8" steel and some coat hangers and a Lil super glue an duct tape...
Old 01-15-2020, 09:35 AM
The 1/8" steel should be bed frames, also
Old 01-15-2020, 09:55 AM
gimpyrobb's Avatar
PM me a shipping address, please.
