Old 01-24-2022, 03:48 PM
C6Z06's Avatar
C6Z06 C6Z06 is offline
Default CNC Plasma Cut Vintage Motorcycles
I cut the following bikes from 11 gauge (1/8") steel with my home made CNC plasma table. I put as much detail into the 19" long figures as possible, keeping at least .150" between interior parts and lines.
BSA Gold Star, Vincent Black Shadow, Matchless 500 single, Ariel Square four, Triumph Bonneville TT Special, Norton Commando, Indian Chief (USA), and early Triumph Thunderbird.
The two larger pictures are the Vincent and the Triumph Thunderbird.
I am not selling these. This is just for fun.
Name:	All Bikes 95 pct.jpg
ID:	163350   Click image for larger version
Name:	Vincent Black Shadow 19 in x 10 in.jpg
ID:	163351   Click image for larger version
Name:	Painted Thunderbird.jpg
Old 01-24-2022, 04:36 PM
jniolon jniolon is offline
would you be interested in doing a vintage truck ??? '53 ford f100.
I've got the pictures for a pattern...
john
ID:	163357   Click image for larger version
ID:	163358   Click image for larger version
Old 01-24-2022, 05:15 PM
astronut's Avatar
astronut astronut is offline
Nice work!
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 01-24-2022, 09:03 PM
C6Z06's Avatar
john
Just do these for fun, and don't mind the work involved. The cost of getting a "one-off" done commercially would probably prohibitively high. I suggest you find something as close as possible by Googling "cnc plasma cut truck wall art."
Old 01-24-2022, 09:32 PM
I'll look around...thanks
Old 01-24-2022, 11:47 PM
camdigger's Avatar
Roving Reporter
Neat stuff! As pretty as the bike silhouettes are, I am more interested in hearing about the homemade plasma table....
Old 01-25-2022, 04:23 AM
Avmech Avmech is offline
Classics very well done!
Old 01-25-2022, 04:40 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
Aren't we all.
cmon vetteman, spill
Old 01-26-2022, 07:26 PM
Scratch Scratch is offline
I thought they looked familiar, then I saw the Plasmaspider post was bumped today and realized who you were.
Nice job on the bikes!
You should show your table, I'm sure members here would be interested in that too!
Old 01-27-2022, 01:51 PM
C6Z06's Avatar
I've used a number of different size CNC plasma tables over the years, and found that my current 2' x 2' x&y travel table satisfies almost all my needs as a hobbyist.
The main advantage of the small table is the ability to use it outside. This makes the plasma dust issue go away.
The first picture below is my current machine. It sits just outside my basement door, with the compressor, plasma cutter, & computer just inside. It takes 5 minutes to run the cables out the door and connect them. The motors stay on the table. I keep a fire pit cover on it for weather protection.
Third picture was a previous table I mounted on casters so I could roll it out my garage door to use.
Name:	2x2 CNC Plasma.jpg
ID:	163396   Click image for larger version
Name:	inside basement door.jpg
ID:	163397   Click image for larger version
Name:	2x2 on casters.jpg
Tags
cnc, harley, motorcycles, plasma, triumph
