Old 02-20-2020, 09:46 AM
Toe clamping the steel block to the table would have been prudent. I failed to sufficiently tighten the indexing fixture, the result was a wondering off of the slot I was cutting.
Just a small bump in the road.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 02-20-2020, 10:44 AM
I suppose when compared to the sink hole and the few pot holes I have encountered on this project.
I blame a combination of mission creep, overconfidence and laziness for the mishaps and subsequent delays with this project. Thinking I could pull this off without drawing it up first was a mistake. Not described in this thread is the embarrassing amount of hours I have spent sitting in a chair staring at this thing. Erasing a few pencil lines is always easier, faster and cheaper than grinding off and rewelding.
Its Okay to talk about what is wrong with society and environment. Behavior that will mitigate these problems will get you shunned.
Old 02-20-2020, 11:29 AM
I usually do not draw things up either. Sometimes I pay for that too.
B biggest
I idot
D democrats
E ever
N nominated
Old 02-20-2020, 06:42 PM
I was confused when I placed this post. I was actually referring to the dump contraption that this winch is to be used for. Modifying this winch was a breeze even without a drawing compared to the rest of the project.
I am actually having more trouble developing a mounting structure for it. Again, without a drawing it has taken me three evenings of staring just to commit to a design.
Old 02-20-2020, 06:54 PM
This is where I’m currently at. I have not completely assembled the winch to ease the handling while I design and make the mounting.
Old 02-23-2020, 03:53 AM
gimpyrobb's Avatar
Sure is cute now! How many feet of cable will it hold?
Old 02-27-2020, 11:17 AM
I did calculate the amount but I don’t remember exactly what I determined, I think it was 52 feet of 5/16” diameter. I only need about 9 feet to operate the dump and I considered making a single row spool that would only hold a few feet but the winch would then be useless for any other task. With 40 feet I could use it for other tasks like trailer loading.
Old 02-27-2020, 11:29 AM
Default Ramsey Worm Winch Modification
This is the mounting structure I made. It is two separate pieces, the top piece bearing most of the load. I wanted to make it as light as possible to ease removal and installation. With the rope installed it will weigh about 90 lbs.
The bottom section acts as a shelf to hold the unit in place while the top section is being secured. The gussets on the top section also act as grab handles. Four 1/2” screws loaded in shear secure the top to the mast.
The picture is upside down.
Old 02-27-2020, 12:18 PM
Please bear with me as I try to rotate the pictures. Something changed on my iphone, so the pictures are not rotating like they used to. Have to find the workaround process.
