![]() 40 HP model# RDS27M Serial#2542246 Based on a little internet digging it looks to be from 1965 So yeah parts might be an issue.
WOW,
40 HP, that's about 4 times what I could use. Way too heavy. Those are pretty simple, not much to go wrong. If it turns over and the coils fire, it could likely be brought back to life. The water pump impeller and most of the hard parts in the lower unit didn't change much until the late 70's- early 80's. The "electra-shift" lowers were the exception, they were junk and problem prone from the giddy-up. Mostly found on the 50 to 85 HP models. Other than scaring the kids 'cause they are 2 stroke, motors like that are still in demand, around fresh water lakes. Dependable, long lived, easy to operate, smooth power. 40 is a Handy size for the heavy 14 - 18 foot 'glass boats of the 60's-70's. Might be worth you investing some spare time to troubleshoot or running past a local OB guy for parts. (what the hell, it's already drug out...) I do appreciate the offer though Thanks, RED
A 160 MPH drive, down a 2 lane blacktop, all by yourself, is NOT anti-social behaviour... I drag race because football, baseball, and golf only need ONE ball. Paul. What I really need to know is, WHEN DOES THE SHOOTING START? |
Yeah, I sort of figured it was overkill for you. I did not remember how big it was until I tackled pulling it out today. No big deal back into the truck it goes along with all the other shit I've hung onto for no logical reason.
Gee, I've never kept junk past the immediate need, (pay no attention to the 2000 sq. ft. building, crammed to the eves, in the side yard.)
what a concept. RED
I usually keep it as long as I don't need it then I get rid of it just before I need it.
I love the smell of napalm in the morning. It smells like, victory! ![]() Rommel, you magnificent bastard, I read your book! Still got the shovel! Victor Torch Set With Meco Regs Lincoln Weld Pak 100 Giant Tech Arc 200 Miller Roughneck2E |
Found it.
Picked up a 1990 6 HP Johnson short shaft for $130.00. Needs a fuel pump and likely a carb cleaning. I'll order a waterpump kit, a new kill switch and a starter rope return spring, just to have them in hand. If I can't make it go or I blow it up, the lower will be a snap to adapt. As before, all good things come to he who waits, as long as he's busting his azz while he waits... Rollin, Rollin, Rollin... RED
