Old 01-22-2020, 05:28 PM
Scotts Scotts is offline
Originally Posted by Gadgeteer View Post
Does the pot output a smooth change in resistance from end to end when run through its full range of motion with meter probes in the connector?
Yes.
Old 01-22-2020, 06:44 PM
MotorDoctor's Avatar
Karma Avenger
Warning: thread drift...
Ran across this photo, obviously the guy that fabricated this pipe liked to weld.
Name:	pipe welding.jpg
Old 01-22-2020, 10:35 PM
Do I have a life?
What is that? Flex pipe with the seams welded? Holey Smokeys!
HF 80 lunchbox w/tig
Old 02-07-2020, 05:35 PM
Well I thought I would update the thread here, I emailed everlast support and got a response back from Mike to check a few things.
Tungsten, contamination or incompatibility was one and he sent me a pinout and test for the foot pedal.
I was able to borrow the same torch I used for the aluminum and the machine worked flawlessly.
Now to put all the covers back on without messing up the thousands of circuits in there.
I am going to strip the torch setup down that was causing the issue and see if I can see what is going on with it.
I did blow all the gunk and spiderwebs out while I had it open.
