Old 01-04-2020, 10:28 AM
jniolon jniolon is offline
Default metal notching
Need some metal working expertise. I know there is a simpler way to notch metal than what I’m using.
I had to fabricate a latch thingy for a neighbor using 3/8” plate which required a rectangular notch to be cut in the plate about 3/4” wide and 3” deep. I used a Metabo grinder with a .040 cutting disc to cut the sides but how to cut the back end of the notch. I thought about a saber saw with a metal blade but the notch was very narrow and it would have been difficult in that small area. Guess I could have used a hole saw at the back of the notch and then squared up with a file...
I couldn’t reach in the gap with a 4.5” grinder to hog it out... finally I drilled a number of holes across the back line of the notch, broke out the slug and finished it with a file to make it square. There has to be a better way. Can’t find a hand tool to handle 3/8” material and notching machines aren’t in my budget..
give me some suggestions and options or ideas, that haven’t dawned on my feeble old brain !
thanks
john
Old 01-04-2020, 11:41 AM
If you have the capability to make a square hole drilling attachment as shown in the Machining forum, then drilling a square hole on the end is the answer.
I'm not that picky so I drill a round one say 3/4" and a 1/8" in each corner. Then I take a dremel with a carbide 1/8 burr and hog out what's left of the corners.
Here.
https://www.youtube.com/watch?v=M3Ul-s9_MA0
Thomas Sowell
Old 01-04-2020, 11:48 AM
digr digr is online now
Here.
Good idea with the 3/4" hole at the end of the 3" slot and leave the rounded corners if you can or square them with a square file if you can't.
or a larger cut off wheel would help.
Old 01-04-2020, 03:15 PM
RED caddy's Avatar
10-28-1951 to 4-19-2021
Da Chief
Might I suggest a ox/acet. torch or plasma cutter (borrowed)
How many do you have to do?
Call a local fab shop, they may have a buffalo with a square punch.
OK, I'm done now... (it's good to own a Bridgeport)
RED
Old 01-04-2020, 05:50 PM
Instead of filing a dremel or die grinder can often take a lot of the corner material out too.
Lots of ways to do that one, plasma, watercut, wire edm, plunge edm, larger angle grinder will all work, depends on what you have and how fussy it is, and how deep your pockets are.
A bandsaw could also be used to take a lot out, keep taking cuts to the line and finish with a file.
Old 01-04-2020, 06:22 PM
I do have a friend with a plasma cutter... next time I'm visiting him...
I only had one to do but looking at future project and a technique
my torch was out of gas... haven't used it in years.
thanks for all the suggestions
john
