Old 12-26-2019, 07:12 AM
Banned
Ought to work well for straight grained stuff. Takes 30 ton here for large cottonwood, especially with crotch branched stuff. My PTO driven screw splitter does the large cottonwood stuff real well.
I have a gas well....
This will never see fire wood, unless I sell it.
Old 12-26-2019, 09:41 AM
Banned
Granted, one could cut that beam off, and re-weld it shorter, simply weld those tapped blocks to the end of the cylinder (there is a pusher plate there)
Better yet, buy a 20 ton (with air assist) and make one 12" wide.
Recall the press brake chart, 20 tons will bend 1/4" plate, 12" wide, using the standard 8x material thickness opening (in this case 2" wide die)
But the work expended would be much more for me. The unit would be much more massive (mount it on wheels).
Anyways, I think it will make a good addition to the mobile shop trailer.
For brackets, linkages and the like.
Old 12-26-2019, 12:20 PM
Norm W's Avatar
Norm W Norm W is offline
A bit off the topic but, how often do you have to soap the gas well? Or do you have an alternate method to get the water out?
Old 12-26-2019, 01:18 PM
Banned
I don't own it, but get free allotment.
Well tender used to use liquid soap, he said my well wouldn't take the sticks.
Now that they have it shut in (price of gas is down) they don't soap it.
Old 12-26-2019, 11:25 PM
OleDog's Avatar
OleDog OleDog is offline
My mom had a Troybilt wood splitter. I thought about repurposing it to make a bender too. I didn't get around to it before my son discovered how handy it is to split wood for his stove. He is living in her house, so the splitter is being used for what it was purchased to do. It doesn't have wheels or a stand, so it's a pain to move around and use, but hey, he's young.
OleDog
Old 12-30-2019, 07:48 AM
Banned
20 tons, 12" wide (able to doo 1/4" plate 12" wide)
https://blockshear.com/mini-stone-splitter
But it's not a open ended design.
I could see this being made smaller. and larger wheels like a hand truck,
put it the "shop van.
Old 12-30-2019, 09:16 PM
rock6.3's Avatar
rock6.3 rock6.3 is offline
I'm seeing a pretty handy press in the making.
Especially if one were to make a plate to convert the splitter V to a flat face:
= hydraulic vise.
= hydraulic press
A series of square tubes of various lengths and it would be very flexible to length.
Making a portable shop (7 x 14 trailer)
Needed a bender. This one has wheels on the one end,
a handle at the wedge end (can roll around like a hand truck)
Figure I can roll it up against the side wall and strap it in place using the e-track I installed
on the walls.
Made from scraps, and the bottom die I had collected.
FWIW any one can doo this, if you don't have a commercial
press brake die, just weld up a "Vee" or a just 2 bars separated
2" or so.
Young enough to be dangerous, old enough to know better (most of the time anyway)
