Old 03-10-2019, 10:59 PM
CactusBob CactusBob is offline
Are you planning on having a slip fit on the tube steel for disassembly?
I was thinking of using slip fittings with square tube, at the corners I could use solid bar and the forge them to 45 deg angles for the inserts. If I use rectangle stock I may make plates to bolt at the corners. Not sure what would work best tho' any suggestions are more than appreciated
Bob
Old 03-11-2019, 10:31 AM
Bob
I dono Bob. down here, round, this neck of the woods. chewtabacky and some creek mud, are the usual go-to fix-alls along with baling wire duct-tape and occasional super glue...
BUT, I would think that square would be the easiest material used in the application of your project...
I think you can just buy slip joint cuppings from specialty steel places like triple-S steel... If there is A TripS location available to you, if not try looking them up on the online cat and take a look-C... possibly have em for rectangular tubing...
If so It would IMO be maybe a bit cheaper over laboring to make em... But slip joint is prolly your best bet for movability purposes...
Would be cool to see it once ur finished I think it a Way-cool project idea and design...
Old 03-11-2019, 01:10 PM
Yea I was thinking of using the duck tap or as we use in Az a bunch of bailing wire but, this is for my daughter and her dog, and well they are both too cute to have it fall so I think something a little stronger might be better. Plus it will keep the wife from burying me under the bed .
I started looking at that catalog and wow they have a lot available.
For the slip couplers would it be better to have it inside or outside, or would it make a difference?
Bob
Old 03-11-2019, 05:45 PM
Bob
Bob, I'm glad you took all that in Stride of it being meant only in a humorous way of which it was intended...
I started looking at that catalog and wow they have a lot available.Bob
If our referring to the triple-S catalog? yep, they have a lot of stuff there.
They have specialty items as well as specialty dimensions of steel products also...
Not sure what shipping steel would cost as they are a local source here... and if i need something its usually a trip over... but they do have a few things to offer that can aid in project related build's or fabrication that might sometimes make thing a bit easier on a guy or gal...
For the slip couplers would it be better to have it inside or outside, or would it make a difference?Bob
Now as for which direction to go. I'm thinking it does not matter. I think it really depends on the Look of the frame project you are looking to come out with.
Now, this is just my opinion as I don't feel one or the other will make much difference of strength per, say... both will be strong enough...
But I am looking at it this way we know both will be strong enough!
but personally, I think if you want it to look cookie cutter commercially designed "Go with the inside couplers" But if your looking for that custom Irion grid type look I'd "Go with the Outer couplings" maybe use your knowledge as a blacksmith to give em a lil bit of a hammered look and there ya go...
"But" also taking into consideration it is for your little girl well she may not like that look of hammered old iron... so really I think that would be your call and maybe get her input on it as well...
Old 03-11-2019, 08:26 PM
weldor2005's Avatar
Perpetuus Discipulus de Vita
I was thinking like a caster bolts to a bolt pattern. Two identical ones, welded like a cap on a mitered steel tube.
Sent from GPS tracking device
David
Finch Fabrication
My YouTube Channel
Old 03-12-2019, 09:28 AM
LOL, yea it was pretty easy to see the humor in that! If you take things to serious this world would be a pretty bleak place
We dont have a TripleS but we do have an Industrial Metal Supply which is very similar, although with the prices I'm thinking a trip to the scrap yard.
LOL, she's 19 and at college right now, hopefully this will be done before she comes home in May, I figure if I put a pink stripe down it she wont even look at how its made.
Now I understand what you meant by a bolt flange, I don't know why I didn't realize that before
Thank you for all the help
Bob
Old 03-12-2019, 11:57 AM
The bolt flange would probably be the easiest but it wouldn't have a very clean look to it. Sockets, or solid inserts would probably look the best.
Old 03-13-2019, 10:15 AM
Having an edge might be an issue if she gets to close, I dont want to leave that sticking out. Hopefully tonight or tomorrow I'll figure out what I want to make this with and then saturday hit the scrap yard
Bob
Old 04-11-2019, 10:50 PM
So, here is the first corner, this will be a slip fitting, 7 more to go!
Old 04-11-2019, 11:10 PM
Ya can't finish without the first step. Your on the way.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
