Old 03-29-2013, 08:53 AM
Burnham Burnham is offline
Default Hose Reel
Have 150 feet of 2" discharge hose that I only use once a year but still got tried of unrolling and rolling it back up so made this simple hose reel. 7" piece of pipe and welded an plate on one end with a 1" shaft in the center, put a slice thru the pipe to so the quick coupler could go into the pipe to allow the hose to lay flat on the pipe. Some 3/8ths rod to make the sides on the reel and 1" sq tube for the stand. a brass bushing pressed into a another pipe to allow the reel to turn.
ID:	103706   Click image for larger version
ID:	103707   Click image for larger version
ID:	103708   Click image for larger version
Old 03-29-2013, 09:16 AM
RED caddy's Avatar
10-28-1951 to 4-19-2021
Da Chief
Nice job.
Did you roll the outside rings yourself, or were they "found parts"?
RED
Old 03-29-2013, 09:43 AM
Nice job another headache out of the way
Old 03-29-2013, 10:36 AM
Floptop's Avatar
Floptop Floptop is offline
I could use that!
Old 03-29-2013, 11:26 AM
22-W's Avatar
22-W 22-W is offline
I could use about four of them. The only problem would be transporting from job to job.
Old 03-29-2013, 12:43 PM
Originally Posted by RED caddy View Post
Nice job.
RED
Rolled them myself, Have a home make roller
Old 03-29-2013, 01:41 PM
Burnham, Good labor saver there and a real nice job.
22-W,If you have a lot of hoses, this might help. One of the guys at the power plant where I worked the last 5 years before retirement had worked for the fire department at one time. He built us a hose coiler that was just a disc with a bearing at about a 45 degree slope. Instead of a pipe in the middle it had a pair of 1 x 1 box tubes about 3 inches long and a 1/2 inch apart at 90 degrees to the disc and a square bar crank that slid into either of the tubes. Just put the hose between the box tubes with the coupling right up close and crank the disc. The hose would wind up around the coupling. When the hose was wound up we would just put a wire around it, pull the crank out of the way toss the coiled hose on a pallet and do another one. One guy could coil up half a dozen hoses in just a few minutes. Build one out of aluminum and it would be pretty portable.
Found a picture on Google of one sorta like it, but ours didn't have a stand and didn't cost 1100.00
Name:	images333 (Medium).jpg
Old 03-29-2013, 05:08 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Should last a lifetime
Boise Paint Contractor
Facebook
How fortunate we are!
Old 03-29-2013, 06:34 PM
22-W's Avatar
Looks like a good rig Fabber. Thanks for the idea.
Old 03-29-2013, 06:35 PM
madam X's Avatar
madam X madam X is offline
One Wonderful Lady!
Rated M for MAGA
