Old 03-25-2013, 04:25 PM
Default AAMetalmaster, you out there??
Bob, I have had some more cast iron repair come into the shop, one of them is mine (intake manifold), the other is an exhaust manifold, and a couple more that are cast brackets. The exhaust manifold is not cooked to death, and is a crack on the outside of one of the tubes, looks pretty easy, the brackets have broken off mounting ears.
I have been wanting to try the Royal 44-30 that you talk about, and so I ordered a 2# spool today. I am considering just putting it in my spool gun and using it from there, but does it work okay going through a MIG gun liner? Also, what is your technique using it, multiple heavy tacks and let cool in between, or just run a bead? Any insight into using it would be appreciated, as at $80 for a 2# spool, I hate to have a steep learning curve.
Old 03-25-2013, 05:32 PM
aametalmaster aametalmaster is offline
Cool
On the exhaust manifold i did my GEO Metro and i ground with a die grinder the crack just to make it shine. Just a little preheat and weld away. Mine was vertical so i spotted it in going uphill but i did one for my neighbor where it was laying flat and i just ran a bead and it was fine. I like 75/25 better than pure argon which leaves a taller bead. The wire runs just like SS. It runs just fine thru my mig liner as the wire is stiff like SS. The intake i would just die grind the crack and try to get a flat weld if you have to prop it up or something but it does do uphill good just spotting it in. Hope this helps. Post some pics...
ID:	103586   Click image for larger version
ID:	103587   Click image for larger version
ID:	103588   Click image for larger version
ID:	103589   Click image for larger version
Bob Wright
Metal Master Fab
Salem, Ohio Birthplace of the Silver and Deming Drill.
http://www.ceilingtrains.com
Miller MM185 with 185 SpoolMate
Old 03-25-2013, 05:38 PM
Cool
Here are a few more pics. If the mounting ears are small just pitch them and fill the area with wire. I used some old mig gun tips where the hole would be and weld over it then grind and drill to size. Other areas where there are broken out bolt holes i used some copper slugs punched on an ironworker and put in the hole and weld around it then drill out the copper. That wire works like a dream. I do work for a local pump rebuilding company and most of it is cosmetic but these parts are high dollar some 20 grand and i have had zero problems...Bob
ID:	103591   Click image for larger version
ID:	103592   Click image for larger version
ID:	103593   Click image for larger version
ID:	103594   Click image for larger version
Bob Wright
Metal Master Fab
Old 03-25-2013, 05:40 PM
Few more...Bob
ID:	103596   Click image for larger version
ID:	103597   Click image for larger version
ID:	103598   Click image for larger version
ID:	103599   Click image for larger version
Bob Wright
Metal Master Fab
Old 03-25-2013, 05:57 PM
Nice job.. What are the weld beads like to grind? Do you notice any extra hardness added to the filler?
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-25-2013, 07:27 PM
Thanks for the advice. Also, any idea on its machine-ability?
Old 03-25-2013, 07:57 PM
Cool
Its machinable...Bob
Bob Wright
Metal Master Fab
Old 03-25-2013, 07:58 PM
Cool
It grinds like SS. No extra hardness that i can tell...Bob
Bob Wright
Metal Master Fab
Old 03-26-2013, 03:09 PM
Pat's Avatar
Pat Pat is offline
Walker,
Did you have to order the roll directly from Crown Alloys, or through some other welders supply place..........thanks.
