Old 03-18-2013, 07:19 PM
WinDancer's Avatar
WinDancer WinDancer is offline
Default Sandblaster problem
My sandblaster [cabinet model] has stopped working properly.
The only way it will do anything except blow air is if I cover the nozzle and give it a little air for a second. Then it will work for a few seconds but even then it pulses, spitting instead of a smooth flow. It stops blowing sand within a minute or so.
I took off the tip to clean it but it was not plugged.
I reversed the tip and that did not help.
I made more holes in the pickup tube and that didn't help.
I taped the end of the pickup tube off, and that didn't help.
I swapped the pickup tube end for end and that didn't help
Every time I pull the pickup tube from the sand the tube is full.
I took some sand out and that didn't help.
I added more sand and that didn't help.
I replaced the factory gun a couple years ago and it has worked just fine since then. I have been very pleased with it until today.
The only other thing I can think to try is empty the cabinet completely and refill with new media.
Any suggestions?
Thanks,
Dave
Dave Evans
http://www.windancerknives.com/
Old 03-18-2013, 07:28 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Dave, the actual sand pick up tube needs to have a tube over it to supply air to the sand pick up tube if there is not sufficient air flow to the tube the sand flow will pulse. The pulsing is caused by vacuum in the sand supply tube over coming the resistance of the sand in the hopper.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 03-18-2013, 07:35 PM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
The inside of the gun may be eroded away...
they wear out after a lot of use and cannot draw adequate vacuum to pull enough sand...
also... might you be experiencing more than normal humidity in your air suppy... have you drained filters?? or replaced wet elements... dessicant or TP..??
Old 03-18-2013, 07:37 PM
Windy_Acres's Avatar
Chairman of the Headboard
What about moisture, that has always been the problem with cabinets and pressure pots. Moist sand does not feed well.
Old 03-18-2013, 07:59 PM
H80N's Avatar
I agree... that is the most common prob.... especially with dustgun blast cabinets... it does not take much to foul mine up even with filters and motorguard tp drier..
Old 03-19-2013, 12:21 AM
gimpyrobb's Avatar
When is the last time you screened the sand? When what you described happens, we empty the sand and pour it on a screen. That keeps the nig hunks of crap out and lets the small sand particles back in to work. The big particles jamb up the flow.
Old 03-19-2013, 11:58 AM
willyfixit willyfixit is offline
Check the transition hose from the sand pick up tube to the gun for a crack or hole.
Willy
Old 03-19-2013, 12:13 PM
Ha the same problems with mine. Put a new gun on, and it now works fine. You can put the suction hose off and pull the trigger. You should feel strong suction at the nipple through all ranges of trigger pull, if not you have a gun problem. If you have good suction then you have a pick up tube problem.
Old 03-23-2013, 01:22 PM
duckman903 duckman903 is offline
We had the same problem as you and cured it. Took a tap from the gun feed line and installed a small needle valve, then ran a line to the suction end of the pick up tube, them started blasting and opened the valve slowly until I got continuous flow of sand the extra air flow stops the plugging.
Old 03-23-2013, 03:51 PM
WinDancer's Avatar
I strained the sand and that helped a little. I then stuck an empty piece of pipe around the horizontal pickup tube. That cured 98% of the problem I was having.
I will leave a small bulb burning on top of the media for a few days and hope that will solve the last little bit.
In the meantime I am back up and running.
Thank you all for the ideas!
Dave
Dave Evans
