Old 03-09-2013, 12:33 AM
getatorch's Avatar
Tuned-Up Big Builder
Thanks for the pics. Looks like you're on the right track with it. Now we need to se cooked food!
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will".
Old 03-09-2013, 04:25 AM
6 inch pipe sounds good to me. You might consider running it all the way to the opposite end and cutting about a 4 inch hole every 6 or 8 inches to let the smoke/heat out. Then you can roll some pieces of tin to fit the outside of the pipe to block off or at least partially close some of the holes. That way you can control what part of the cooking chamber gets the smoke directly and what doesn't. Easier to reach a poker in under the grate and slide some tin around than move the meat all over the place to get the temperature and smoke level you want. You could tack a washer on edge to fit the poker into.
Just an idea to mull over.
Old 03-09-2013, 07:01 AM
Looks like things are moving along.. Humvee I like the looks of that monster.. Is I permanently mounted on that trailer?
Is that a seat I see on the far side or is that a shelf?
Did I mention I really like smoked Salmon..
Dr Bob, I'm not a vegan.. and since the shot gun rule applies you just gotta get in line.. What ever happened to Ladies before Gentlemen..
Oh, yeah.. I'm gonna role out that card. .And heck I'll even through a skirt on and some heels if I gotta.. Not that it takes much.
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-09-2013, 09:42 AM
Hummve Hummve is offline
I like the idea of holes along the pipe for tuning. Now you have the wheels turning in my head to pull that off. I've got an idea now too possibly control the openings from the outside of the smoker. Hard to explain maybe I will draft it up real fast.
The large smoker is bolted to some channel running across the side rails that are reinforced from the frame of the trailer.
Old 03-16-2013, 05:34 PM
Progress! I've gotten a lot done in the last few weeks just been slow about posting. I decided to go with the 6 inch pipe for the baffle. I am still curious about the distance the stack should be above the cooking surface any input would be much appreciated.
Old 03-16-2013, 05:53 PM
Put some temporary legs to get it off the ground and level.
Name:	2013-03-16 16.45.41.png
ID:	103112   Click image for larger version
Name:	2013-03-16 16.50.10.png
ID:	103113   Click image for larger version
Name:	2013-03-16 16.50.38.png
ID:	103114   Click image for larger version
Name:	2013-03-16 16.52.13.png
Old 03-17-2013, 07:49 PM
A little more done today.
Old 03-31-2013, 10:14 PM
Haven't had much time lately to get much done but here are some action shots building the burners.
ID:	103793   Click image for larger version
ID:	103794   Click image for larger version
Old 03-31-2013, 10:37 PM
SmokinDodge's Avatar
Holy BTU's Batman!
That is some serious azz burner.
Sent from my iPhone using SFT
Old 04-01-2013, 06:23 AM
I have to confess I'm ignorant when it comes to burners and such..
How long will the pipe burner last if the flame is under it?
How much gas you having to run?
_________________
Jennifer
My google+ page
DoALL 36"
