Old 09-11-2012, 02:54 PM
Big_Eddy's Avatar
Big_Eddy Big_Eddy is offline
I have a friend who's wife works for a roofing company. I was lucky enough to get a bin full of copper scraps from them a few years back. I made a number of flowers and leaves using these scraps. I used tin snips to cut them out, then used a ball pein hammer to texture them, focussing on the edges to remove all evidence of the snips. I used copper water line (fridge) and wire for stems and trunks, tigging them on. Tigging copper is fun!
I still have a jug of pickling vinegar under my laundry tub that I used to brighten up copper items. I wouldn't worry about discolouration while making them, then would soak them for a day or 2 in the vinegar. I would then add colour back using a propane torch and clearcoat them.
I gave him back a couple of copper roses and we called it even.
Old 09-11-2012, 03:38 PM
camdigger's Avatar
Roving Reporter
Out of curiosity, did you have to anneal the copper before the hammer work?
Old 09-12-2012, 11:20 AM
Big_Eddy's Avatar
I didn't anneal the copper before the hammer work. I did find that the copper would tend to work harden and I used my propane torch to heat it after hammering. Made the next steps in forming petals with pliers a lot easier. If I did too much hammering along the edges there would be small cracks that formed unless I "softened" the copper by heating it and allowing it to cool again.
Never did figure out the magic combination of heating and cooling but would heat to the point where the copper would change colour then allow to air cool. I probably should have looked up the proper method but it did the trick well enough for what I was doing.
Old 09-12-2012, 12:11 PM
camdigger's Avatar
Roving Reporter
AFAIK, copper anneals by the temperature cycling you have done.
Old 09-12-2012, 05:44 PM
edwardn's Avatar
edwardn edwardn is offline
Good deal on the copper, I wish I had contacts like that... next time home i will go through the copper rose thread posted on here and give it a go, sorry at the moment I cant remember who posted it but it is a great thread.
Camdigger, I annealed the leaves when i brazed the stems on but in hind site that made it tougher cleaning them on the wire wheel because they were so soft until I learnt to wire wheel the front first then the back as when I did it this way the out side of the leaves bent forward giving them a more natural look... in the end when i started using the acid ( toilet bowl cleaner ) it wouldnt matter if they were annealed as the acid cleaned them enough as to reduce the amount of cleaning needed on the wire wheel. On the other hand some peices such as the towel on the golf bags were annealed a few times to prevent them from cracking.
Cheers
EDD
4X8 Drop side Dynatorch CNC plasma Table
1250 Hypertherm plasma cutter
Hobart Handler 187
King 7x12 Metal Bandsaw
Ridgid 12" Compound Miter saw
Ridgid 10" table saw
Ridgid 15" Drill Press
Old 04-05-2013, 01:14 PM
CopperSmith CopperSmith is offline
That is some excellent copper work ED.
Browse the Collection.
CopperSmithCollection.com
Old 04-05-2013, 01:22 PM
Thumbs up
Nice update on your thread here Ed. I love the golf bags.
I know of one dedicated golfer here at work, but don't think enough of him to spend any time on a project for him like this.
