Old 01-01-2012, 10:39 AM
moose's Avatar
moose moose is offline
Default Making a copper rose
One of the images I posted in my intro was a rose made from copper. I was asked if I had progress photos. What follows are the progress photos with a naritave of how I mkae them.
As stated these are made from copper sheet. The sheet I use is nothing more tham roof flashing I get from the local supply house.
Similar techniques can be used to make them from sheet steel and welding as apposed to soldering.
Grab a coffee of other beverage of choice and I hope enjoy.......
I start out by laying my templetes out to maxamize the use of materials, trace them out and cut.
I next anneal then pickle them. To anneal them I justheat till a dull red color. This makes the copper softer and easier to form,I pickle them in a solution made by using pool Ph balancer which is mostly sodium bisulfate desolved in water them warmed in an old crock pot. The pickle remoces the oxidation left from the annealing process.
I start by tinning the tip of the stem. For the stem I use copper tubing.
This allows the pedal clusters to more easily attach as they are added.
ID:	85883   Click image for larger version
ID:	85884   Click image for larger version
Name:	3-parts and pieces.jpg
ID:	85885   Click image for larger version
Name:	4-anneal parts.jpg
ID:	85886   Click image for larger version
Old 01-01-2012, 10:51 AM
moose's Avatar
Default making a copper rose cont.
Each cluster had a hole punched or drilled inits center to allow it to be slid onto the stem
I continue by adding the pedal clusters smallest first
I roughly form them as they are added starting with the bud center
each layer is them added and turned up and then twisted to simulate the pedals of a real rose
Name:	5a-start to build.jpg
ID:	85888   Click image for larger version
ID:	85889   Click image for larger version
Name:	7-second layer.jpg
ID:	85890   Click image for larger version
ID:	85891   Click image for larger version
Name:	9a-twisting pedal.jpg
Old 01-01-2012, 11:00 AM
moose's Avatar
Default copper rose cont
the last piece added to the blossum stack is the sepal
I then move on to the leaves
I start by added a piece of copper wire to the leaf and either add omre leafs or attach the single leaf to the stem
when I am finished assembling the bossumI manipulate the pedals with round pliers to add the twists and folds till it is pleasing to my eye.
You will end up with a rose similar to this........
ID:	85893   Click image for larger version
ID:	85894   Click image for larger version
ID:	85895   Click image for larger version
Name:	12-leaf added.jpg
ID:	85896   Click image for larger version
Old 01-01-2012, 11:06 AM
moose's Avatar
Here is how I make the leaves
I start out by cutting the laf shape and annealing them
I then use a lengthe of welding rod ot emboss the main vein
I next use a piece of rod formed into a Vee to add the side veins
Them are inprinted by setting the leaf on a rubber pad or my shot bad and hammering the rod into the leaf piece
I use snips of nibblers to add a varigated edge if that is the look I am after
This created a realistic looking leaf.........
ID:	85902   Click image for larger version
ID:	85903   Click image for larger version
ID:	85904   Click image for larger version
Old 01-01-2012, 11:14 AM
moose's Avatar
Default copper roses cont
here are a few I have made.....
each is slightly different and with a different patina
as shown you can vary the display by boxing tehm in a shabow box
twisting the bottom of the stem to form a base or just lay them on a shelf..
ID:	85906   Click image for larger version
ID:	85907   Click image for larger version
ID:	85908   Click image for larger version
ID:	85909   Click image for larger version
Old 01-01-2012, 11:43 AM
Pat's Avatar
Pat Pat is offline
Moose,
Thank you very much for the A-Z copper rose making information. Thanks to your excellent photos I can see where you have some time saving procedures I can use when I make my next batch. Now if I can get a couple helpers like you have I can just sit back and watch the work progress...... Real nice work......thanks again.
Old 01-01-2012, 12:16 PM
Charlie C's Avatar
More STEAM!!
Very nice job.
A couple of steps that I can add to mine next time also.
Old 01-01-2012, 01:21 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Pretty cool Moose
Boise Paint Contractor
Facebook
How fortunate we are!
Old 01-01-2012, 01:31 PM
Mild Steel's Avatar
Mild Steel Mild Steel is offline
Your roses are absolutely gorgeous!! I really appreciate the well documented, step by step process. You have inspired me to try making one in the near future.
Still trying to be the man my dog thinks I am.
Old 01-01-2012, 02:38 PM
Moose,
Very nice project, thanks for sharing
in post #4, the first picture, the young girl (daughter or granddaughter??) she is standing in front of a tool cart. I have one of them, mine is a Craftsman and I've never seen another one. I got mine about 28-30 years ago, when I was working in a cycle shop, fixing Honda, Kawasaki, Suzuki and Yamaha motorcycles.
