Old 02-20-2021, 07:23 PM
Default Compothane/Urethane hammers
For about the last 20+ yrs, I’ve used nothing but compothane/urethane hammers, either soft dead blows or ball pein hammers. I probably own somewhere close to 75 hammers and not a single wooden handled one in the inventory. Earlier this week, during a 24” diameter stack damper build, I whacked a center punch, and the compothane/urethane covering started to fall off. I switched hammers and finished the job. I then super glued the pieces back onto the metal frame.
Early compothane/urethane hammers had a chemical problem, which lead to cracking, oil oozing out of the covering and severe flacking. Snap-On, Stanley and a few other companies, got involved in a lawsuit, that lead to a very liberal warranty return program. Unfortunately, my hammer has been severely abused, welding scars, melted grooves in coating and other numerous battle scars. I in good conscience, would not even try to claim warranty replacement, based on my abuse.
Earlier today, I started looking for a replacement hammer, I went to Trusty-Cook, to get a price quote. After about 20 minutes, I ended up ordering a 4 piece set a 26 oz, 32 oz, 47 oz and a 50 oz, set of metal faced ball pein
https://trustycook.com/product/ball-peen-hammer-4pack/
Old 02-20-2021, 07:43 PM
Never heard of the outfit before Jack. But, that looks like a sweet set of hammers.
Old 02-20-2021, 09:28 PM
OK , Jack I do have a question. Compothane /Urethane to reduce punishment on your body or do you feel it gives you more control or some other factor?
Old 02-20-2021, 09:51 PM
Dramatically less rebound, better control, a lighter hammer, works like a heavier hammer, better on my surgical repaired shoulder.
Old 02-20-2021, 10:07 PM
Thanks for the reply Jack. I suspected you had good hard earned reasons for your choice.
Old 02-21-2021, 12:54 AM
I had a hammer that shed it's outer skin years ago. I never knew there was a warranty replacement, but then again I did not pay for the hammer in the first place.
Old 02-21-2021, 01:04 PM
The other advantage is, as Jack mentioned, rarely do they suffer from handle failure. A lot of my wooden handled hammers, tight for years in Onterrible, now have loose heads due to the wood shrinking in the drier air here in Alberta.
Old 02-21-2021, 03:53 PM
460 Delta's Avatar
460 Delta 460 Delta is offline
It can go from no humidity in the winter here, to hazy humidity in summer in the Ohio valley. Hammers do get loose here, so I dropped a couple sledges in a pan of used anti-freeze one day. The ethylene glycol doesn't evaporate quite like water does, heads stay tight after a days soak in a pan.
Perfection is the enemy of good enough.
Old 02-21-2021, 05:10 PM
Pure glycerin will lock them down for a long time . Just soak the heads in a bucket .
Old 02-21-2021, 05:36 PM
Windy_Acres's Avatar
Chairman of the Headboard
Nice hammer Jack, nice thread guys, I learned allot !
