Old 12-28-2020, 08:57 PM
Default D1-4 x ER 40 ColletChuck Arrived Today
As the title says the D1-4 x ER 40 collet chuck arrived today, I ordered it Christmas Eve, it arrive Amazon (USPS), late this afternoon. I had to adjust the mounting pins (trial and error), but it all worked out in the end. The runout was very acceptable (for me) and was well below the 3 jaw chuck. The fractional collets I ordered, will be here in about a week and the R8 x ER 40 collet chuck has shipped and should be here by 1/5/21.
ID:	158996   Click image for larger version
ID:	158997   Click image for larger version
Old 12-28-2020, 09:43 PM
Gee, thanks for raising the bar again for my home shop.
With you talking about adjusting the pins, reminds me of when I sometimes have to use the four jaw chuck that the other machinest has for his machine. I use it sometimes because it has a bit bigger hole in the center, but I have to turn the pins in two turns to make it fit my lathe.
Old 12-29-2020, 03:21 AM
Those are nice little chucks--I bought one a couple years ago. My lathe has a D1-6 spindle
and I couldn't find one with a direct mount so I had to adapt it to a D1-6 backing plate I had
kicking around. It worked out perfectly and for all intents and purposes there is no more than
a couple tenths runout on a mounted workpiece. I don't use it that often but it's perfect for
holding small, fussy parts. Highly recommended...
