Old 10-31-2020, 03:54 PM
Default New Drill Bit Sharpener
Last Sunday Night, I finally broke down and bought a new motorized drill bit sharpener a MR-26A, that sharpens all bits between 13 - 26 mm (1/2” to 1-1/16”) drill bits.
It arrived at the home shop on Thursday, the wife bitched loudly, as it weighed 65#. The unit uses ER 40 collets (supplied with the unit) to hold the drill bit accurately, while being sharpened. You set the diameter, set the drill in the collet chuck, then sharpen the drill bit, then you can split the point, if you want to.
Today I sharpened about 50 drill bits, ranging from 1/2” to 15/16”, I very impressed, with the ease of the procedure and the speed of the procedure. I did one 3/4” bit that looked like an enraged badger had gnawed on it and in less than a minute, it was better than new.
Welp!! I was so impressed, that after my phone conversation with MiloMilo, I bought the MR-13A version that does 3 - 13 mm (1/8” - 1/2”) drill bits. It should be here by next Friday.
ID:	158237   Click image for larger version
ID:	158238   Click image for larger version
Old 10-31-2020, 04:33 PM
seagiant's Avatar
seagiant seagiant is offline
Hi,
Hmmm....Nice, I wonder if it uses the same operating principle as my somewhat cheaper Drill Doctor???
“If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace.
We ask not your counsels or arms.
Crouch down and lick the hands which feed you.
May your chains set lightly upon you, and may posterity forget that ye were our countrymen.” -Samuel Adams
Old 10-31-2020, 05:21 PM
Originally Posted by seagiant View Post
Hi,
I have Drill Doctors, it’s very close to the similar Drill Doctor principle, but it’s a lot more precision based and the result are stellar. While the Drill Doctor has very acceptable results, the new unit is about 3 or 4 steps above, better than some of the new drills I’ve seen in the stores.
Old 10-31-2020, 05:46 PM
Teach her how to run it, and she can do "Drill bit sharpening while you wait, walk-ins welcome"....
"Egg Money"....
Old 10-31-2020, 06:30 PM
seagiant's Avatar
Hi,
Thanks, I wanted a DAREX, but even that was pricey and I'm just a hobbiest.
The Drill Doctor I have was close and does a pretty good job for what I need.
How much was your machine, or did I miss that???
Old 10-31-2020, 06:48 PM
Nice machine!!!
Old 10-31-2020, 07:12 PM
Hi,
Slightly south of $300
Old 10-31-2020, 08:24 PM
seagiant's Avatar
Hi,
Hell, that's great if it makes you happy.
I think the DAREX is about $1000 and my Drill Doctor is copied from it, of course!
Old 10-31-2020, 08:34 PM
That's way cheaper than I figured.
Old 10-31-2020, 10:26 PM
Samcord Samcord is offline
Is that the MR13, or the MR26?
