Old 11-06-2020, 03:38 PM
platypus20's Avatar
Boiler God
Welp!! After being told it would be delivered between 11/17 - 11/24, the smaller MR-13B arrived by DHL currier at 1:30 pm, today. Iā€™m in the process of getting ready for the trip to Kansas in the morning, but I had to try it out before I left. It work jut like the bigger MR-26A unit, the results were spectacular. The unit is about 1/3 the size and weight of the bigger unit. So dull drill bits in the 5/64ā€ to 1-1/16ā€ (2 mm - 26 mm) range, should no longer be an issue.
ID:	158375   Click image for larger version
ID:	158376   Click image for larger version
ID:	158377   Click image for larger version
jack
Old 11-12-2020, 07:32 AM
Got the larger one last night.....damn it is heavy.
Pried off the entrails of a wood box, and it looks like it's all there, and the motor
sounds quiet.
will try it later on.
Thank you again for the heads up, I have looked at them for years, but they were always much more expensive.
Old 11-16-2020, 03:12 PM
nelstomlinson nelstomlinson is offline
Originally Posted by seagiant View Post
Hi,
Hmmm....Nice, I wonder if it uses the same operating principle as my somewhat cheaper Drill Doctor???
I got one of the drill doctors. It's mostly plastic, and works better than I can do it freehand. Of course, I cannot sharpen drills freehand at all. Once I've sharpened a dull drill, it definitely cuts better, and I really can't tell that the two edges are different lengths and it's wobbling and cutting oversize. I'm not doing precision work, so it doesn't matter if it's a bit off.
Old 12-14-2020, 01:49 PM
Finally tested it out.
Works very well.
I would like to suggest the fan on the grinding wheel, would be nice
if it had a duct out back to suction all the grit out of the way.
My concern is those nice, accurate bores & mechanisms will get
damaged by all of it just "flying around".
I've looked at the smaller one, however the price is still double
of the larger one.
I wonder if I could just buy a set of collets for the smaller drills, and run them on the big one ?
Old 12-14-2020, 01:51 PM
I paid $239 including shipping.
Much better all around than the DD.
Old 01-04-2021, 10:13 PM
animal animal is offline
Default Sharpener
Doug , it's been a few months now . What's your opinion now on the sharpeners ? Still pleased ? I'm thinking real hard bout buying one . I found the smaller one MR-13 on Ebay for $ 243.10 with free shipping . & 1 for $239 on Amazon . Do you remember which vendor you bought from on Amazon ?
HAve you used it to sharpen any end mill ?
thanks
animal
Old 01-05-2021, 07:47 AM
thanks
animal
I have used it, works well.
don't recall the vendor, only that the sale price is now gone.
Have not any end mills, sold milling machine years ago.
EDIT: now that the 2-13mm grinder price has come down, I just looked at them.
I only see (2) holes for grinding, it appears these machine don't doo the split point.
The larger ones (13-26mm) have 3 holes, doo a very nice split point.
Old 01-05-2021, 04:05 PM
Better than the drill doctor is really a pretty low bar. If I had known about this option, I would have gone with it. The DD is good enough for my very low precision needs, so I probably won't upgrade.
  #29
Old 01-07-2021, 05:28 PM
platypus20's Avatar
Boiler God
I thought a DD was very good at what it does. Yes, I went to the better units, more for consistently good results. If I had not bought the better units, I could have survived with the DD.
jack
  #30
Old 01-07-2021, 09:55 PM
I have one of the first ones ever made and it still works just fine.
THE STORY:
Back in the dim dark ages before I retired (which has been 23 years now) there
was a thing called "Usenet" . I followed "Rec Woodworking" and "Rec Crafts Metalworking". There appeared a post from some sort of a "sales man" or advertising person regarding this thing called a Drill Doctor with a lot of talk etc. and the offer of several free ones for a message detailing why one would like to have it and any other pertinent things. So ginned up a nice note and fired it off to him. Lo and Behold about a week or maybe two later the package arrived with it I've been using it ever since. :-)
...lew...
