Old 02-23-2024, 02:31 AM
Hoggo Hoggo is offline
Yobbo
Default Just some small stuff.
Yesterday I made another twin lobe points cam. The original I made worked fine, but was slightly out, so I did a little more filing, too much ask it turned out, a few swipes with a file took it past the midway point on the backing plate adjustment.. I've made a few of these points cam, very difficult to get accurate, one swipe of the file can ruin a hole days work. But this one I got spot on for both cylinders. Today, I made a clamp to hold a bit of felt to lube the cam, very small exacting work. After all that I polished the cam and backing plate, just because something isn't seen doesn'mean it shouldn't be shiny. I once polished the rocker arms on a Bonny.
ID:	170214   Click image for larger version
ID:	170215   Click image for larger version
ID:	170216   Click image for larger version
Old 02-23-2024, 02:51 PM
I don't remember what you did in your other post.
correct me if I'm wrong,
you first converter from a dual point system to a single point ?
are you using an electronic ignition with the current setup?
Old 02-23-2024, 04:46 PM
Yobbo
Points, dual output coil, condenser. No electronics.
