Old 09-15-2019, 04:35 PM
Default Another leak
Recently I acquired another yellow nigger, a Komatsu PC20. Camdigger and i looked at it when I was at his place. Then, with some trading, Cam hauled the thing home.
During testing and the ride home, there was no sign of an oil leak, as I was watching for that. The Hyd tank was a bit low, though. So once it arrived and it stopped raining, I went out to play in the mud. All went well, happy with the breakout force compared to a Kubota, and then I started leaving a trail of oil.
I drove it into the shop, it bled all over the apron and the floor, it's a mess in there now, I'm working on that, about 3-4 gallons of oil to suck up.
So, between my wife and I we figured one of the hard lines was dripping. Today we finally got at it and removed the line and it looks like a rock burrowed in and found a home.
So I boiled it in a red heat to get the oil out of it, and went ahead and tig welded it. Used some rebar wire for filler. Even with prep and cleaning I still had enough carbon particles to leave a blow hole, so I re-welded the spot and the problem left the site.
I used varsol to test it and it passed, but if it wasn't metric I could have pressurized it with air.
Margot was under the machine cleaning and she greased the circle gear, and also was a the main tool fetcher.
So now all is well and I hope that is the last problem for a while.
ID:	152209   Click image for larger version
ID:	152210   Click image for larger version
ID:	152211   Click image for larger version
Old 09-15-2019, 04:56 PM
Looks well sealed now.
Old 09-15-2019, 05:26 PM
I usually braze those, looks good
Old 09-15-2019, 06:53 PM
We have fixed lots of worn lines like that--my brother usually uses everdur rod with the tig torch. I actually think he's found something that he likes even better--don't know what it is since tig welding is his department...
Old 09-15-2019, 07:46 PM
I think coat hangers work better than rebar wire. That would probably make your brother shudder
I debated using silver solder with the tig welder, but the roll of wire was closer.
Old 09-15-2019, 08:27 PM
camdigger's Avatar
Roving Reporter
Glad you were able to fix it relatively inexpensively.
What function was the line for? Rotation of the body perhaps?
Old 09-15-2019, 08:44 PM
Tramming in reverse on the right track. It is in a unprotected spot and has 2 more hardlines stacked above it, so a rock behind there could never get out.
Most of the drive motor lines are behind a guard plate but that corner is not covered.
Old 09-15-2019, 11:26 PM
Will you be engineering something?
TA 95 lunchbox w/tig
Old 09-16-2019, 05:50 AM
Nice looking digger there. I am jealous.
Nice tig weld. I usually use SS tig Rod on regular carbon steel.
I welded up a rub hole on forklift line years ago, and to my knowledge it is still working. Of course, since it been almost two years since I moved on, I would not know for sure.
Old 09-16-2019, 07:33 AM
No, I don't think so. It is right on a corner, and I think a bit of pressure washing now and then, and inspecting the area is better. If I catch anythin in there again, all I would do is tuck in a piece of foam rubber to fill behind the tubes on the corner where they form a pocket. Then gravel can't get in there to rub.
