Old 09-07-2019, 05:17 PM
digr digr is online now
Default Fuel tank
The man wanted his old headache rack and a new fuel tank mounted on his 2011 Ford F350 and still have his roll up Tonneau Cover mounted behind it. Does anyone have any ideas for a rubber molding to make a water tight seal around the tank? I will not be shortening the Tonneau Cover.
1 tank surround
2 everything in place
3 gaps
4 bolt on cover for strobe flasher
5 flasher
ID:	152116   Click image for larger version
ID:	152117   Click image for larger version
ID:	152118   Click image for larger version
ID:	152119   Click image for larger version
Old 09-07-2019, 09:09 PM
Maybe truck/heavy equipment window gaskets or trash truck tailgate seals https://www.holtzindustries.com/tailgate-seals-2/
Old 09-07-2019, 09:45 PM
Thanks for the heads up I think you found the answer!
Old 09-10-2019, 12:11 AM
Scrapper Greg's Avatar
Ted, if that doesn't work, try https://www.steelerubber.com/ they have a lot of stuff too.
MAGA
Old 10-02-2019, 04:27 PM
Its done
ID:	152393   Click image for larger version
ID:	152394   Click image for larger version
