Old 10-19-2016, 06:23 PM
Camaro Zach's Avatar
Thank you all.
I am bad about getting progress pictures now that I only have a phone to use. And many of my projects don't even get photographed before they head out the door I am going to try and change that though.
I don't own an English wheel or planishing hammer so I don't have a way to smooth out any "panel beating" one day I would love to though. All of the shapes were formed with a brake and a bead roller.
Sent from my iPhone using SFT
ID:	136216   Click image for larger version
ID:	136217   Click image for larger version
ID:	136218   Click image for larger version
Buggy
Old 10-19-2016, 06:39 PM
Here are some more of the bumper.
[*] the entire corner of the bedside is cut to allow the bumper to sink into it. Then I bent and tacked in 3/8" square bar to finish off the edge of the sheetmetal.[*] I had to form the curves around the license plate with the handle of a dolly and my hands.[*] here you can see where I was using tape to mimic the bead rolling to figure out what looked best.[*] the corners of the bumper are formed from 2 pieces of sheetmetal each to retain a faint body line near the bottom
ID:	136223   Click image for larger version
ID:	136224   Click image for larger version
ID:	136225   Click image for larger version
Buggy
Old 10-19-2016, 08:55 PM
So Zach, how do you access the radiator cap?
Old 10-20-2016, 06:34 AM
rmack898's Avatar
rmack898 rmack898 is offline
That HURT!
Zach,
I'd like to see some pics of your bead roller and what dies you use.
Mac
Old 10-21-2016, 01:00 AM
Originally Posted by SmokinDodge View Post
Very nice Zach. Sometime I'd like to see the whole layout and metal forming process to make those panels under the hood.
If I do some more I will make sure to take more pics. I will say though I usually make as many pieces out of cardboard as I can so when the sheetmetal Needs minimal final trim and fit.
you can see my cardboard version was going to have an access hole but the owner said no. 10 stainless #10-24 and that panel can be lifted out of the way.
Originally Posted by rmack898 View Post
Zach, I'd like to see some pics of your bead roller and what dies you use. Sent from my iPhone using SFT
Nothing special. Just the guts of a harbor freight roller in a new frame. Here is a pic shortly after I first modified it. Now it has a wheel instead of a handle. I can take some pics of the dies it comes with if you would like but I haven't made any custom ones yet.
Buggy
Old 10-21-2016, 08:54 PM
rmack898's Avatar
That HURT!
Thanks Zach,
I have my eye on the HF bead roller and have been reading all of the modification threads over the net and have a few ideas of my own to make it a useable tool. I'll most likely pick one up the next time I get up HF way.
Mac
Old 10-22-2016, 04:19 AM
Thanks Zach, I have my eye on the HF bead roller and have been reading all of the modification threads over the net and have a few ideas of my own to make it a useable tool. I'll most likely pick one up the next time I get up HF way.
if you end up with one I would like to see the modifications to improve it. Honestly mine is a bit neglected in the modification department and is just good enough for the stuff I build out of steel but I think it would wreck some aluminum. One big thing mine needs is a good way to control lateral movement of the shafts when using the step dies. The width/height of the step can vary if you don't pay attention to it.
Buggy
Old 09-16-2019, 07:53 PM
i Made a bandsaw stand with a HF portaband a few years ago: pic 1 price was right ($99)and I needed it thrown together quickly at the time. I have since acquired a m18 Milwaukee cordless portaband so I can afford to have my old corded Milwaukee portaband permanently mounted.
Fabbed up a stand from some scraps of 1/4”x8” flat bar, 2”square tube, and 3x3” angle
The Milwaukee is soo much quieter and smoother running. I am giving the old setup to my dad so that it doesn’t go to waste.
ID:	152224   Click image for larger version
ID:	152225   Click image for larger version
Buggy
Old 09-16-2019, 09:51 PM
chumly2071's Avatar
Urban Gunfighter
You've always done good work...
Far surpassed my abilities, that is for sure.
Old 09-17-2019, 11:09 PM
Thank you.
Buggy
