Old 04-24-2008, 06:40 PM
markct markct is offline
Send a message via Yahoo to markct
Default lincoln idealarc tig 300/300 no output on tig
i just got a lincoln idealarc tig, bought it real cheap, i hooked it up and it works great on the stick welding setting, but i have no output on the inert gas welding setting. any ideas on what could be wrong, any common things to check before i send it off to the repair shop? i dont know exactly what setting it should be on to get tig output, it has a switch for gas, or stick, a switch for soft start on and off, and a switch for spark, with an off on and start only position, as well as the ac, and dc switch and of course amp settings
Old 04-24-2008, 07:09 PM
Looks like there's more then one manual.
Is this the one ?
http://content.lincolnelectric.com/p..._IMS/IM333.pdf
Old 04-24-2008, 07:17 PM
sorry gwiz but whenever i try to open that pdf my old junky computer freezes. the welder is the older style with the big square housing and relatively flat top with a ring in the center, not the early rounded top. i dont know how old it is
Old 04-24-2008, 07:24 PM
Try This.
Old 04-24-2008, 07:33 PM
hmm ok so i think i may have been overlooking a simple thing here! since up near the plug for the foot pedal it has a switch that says panel or remote i had been thinking that on panel it would work without the pedal, which i dont have, but now that i think of it yea how would it know to turn on the gas and all! duh silly me, looks like i gota find a pedal and try it that way! thanks for pointing this out to me, its logical just slipped by my mind
Old 04-24-2008, 07:41 PM
I'll have to get back to you later.
Read it again, I don't think you need the pedal at this time
"Remote OR arc start switch".
The manual is hard to read I'll have to print it and see what I come up with.
