  #51
Old 12-05-2018, 10:49 PM
Chris This the one you needed yes..
Will try to get it sent off tomorrow if not will be Friday..
Attachment 148385Attachment 148386
That's the one. The box looks exactly like the ones that came with the mill. Did not really look at the name, but same color. Thanks.
Harry S. Truman
  #52
Old 12-05-2018, 10:51 PM
Can't you drill out the tapped hole a 1/16"?
DUH!! That never occurred to me. I will check tomorrow.
Harry S. Truman
  #53
Old 12-05-2018, 10:59 PM
This would be a worthwhile add on
Odd that you should mention that as I was cleaning off the front of scale on the Z and thought it would be much better with a dial indicator. I need to look more at that shortly.
Harry S. Truman
  #54
Old 12-06-2018, 12:38 AM
...That's the one. The box looks exactly like the ones that came with the mill...
I wouldn't worry too much about odd-sized R8 collets. Unlike 5C or ER collets R8s are designed to hold tools, not workpieces so you can probably cover 99 per cent of what you need with 1/4", 3.8", 1/2", 5/8" and 3/4". On the other hand having a range of 5C and ER collets is really handy because you'll can use them for holding pins and small shafts of various diameters...
  #55
Old 12-06-2018, 06:58 AM
I'm not sure the collet if the is same as the box did not open it up from the plastic he just grabbed the box and looked through a few collets and stuck it in that box
I did see the top of collet said the same size as on box have no idea if the collet is chinesium or not
  #56
Old 12-06-2018, 10:09 AM
Import or brand is not important.
Harry S. Truman
  #57
Old 12-06-2018, 10:13 AM
Got a bid in on a Phase II coaxial indicator with 6 stems. We will see if I win it.
Harry S. Truman
  #58
Old 12-09-2018, 01:26 PM
Picked up the flat allen head screws last Friday at Fastenal in Cheyenne. The vise is all done now. Tomorrow Walter and I are going to tram the table and see if we need to shim the column to get it plumb to the table.
Harry S. Truman
  #59
Old 12-21-2018, 09:31 PM
Had a missing arm on the mill down feed when I bought it. Made one from stainless to match the existing. 5/8" round with 1/2-13 threaded ends. Turned the ends on the lathe and cut the threads. Got 3 news ball ends as the old ones were kind of pear shaped, and as I expected, no luck in finding that type.
Used a $5 off at Ace Hardware so saved a bit.
ID:	148531   Click image for larger version
ID:	148532   Click image for larger version
ID:	148533   Click image for larger version
Harry S. Truman
  #60
Old 12-21-2018, 09:37 PM
Made a new handle for the mill vise. It came with a home made one that was pretty crude. Found a 8 point 3/4" socket and had a spare 1/2" breaker bar, both older Craftsman stuff. Ought to work well for me.
ID:	148535   Click image for larger version
ID:	148536   Click image for larger version
Harry S. Truman
