Old 11-26-2018, 01:44 PM
Default New Stand
I don't, for the life of me, see how I can use these stands in my particular situation.
Looks to be impossible to correctly level the machine, considering there aren't any feet, just a flat surface.
My floor is wood, and sloping 1/4" per running foot lengthwise to the machine.
I have a similar stand underneath my mill, and it's less than vibration free. Annoying when using a boring head, or taking heavy cuts with other tooling.
Gonna build a new stand (PITA time user upper) out of square tubing that has 4 distinct feet contacting the floor supports/plates.
ID:	148268   Click image for larger version
ID:	148269   Click image for larger version
ID:	148270   Click image for larger version
http://www.farmersamm.com/
Old 11-26-2018, 01:55 PM
Just add some adjustable feet.
“Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves"
William Pitt (the Younger), Speech in the House of Commons, November 18, 1783
Old 11-26-2018, 02:00 PM
+1 for sure!! nice stands
Old 11-26-2018, 02:43 PM
Do y'all honestly think adjustable pads would work? I've never put one of these together.
I'm not thrilled with the flat stock under the stands, doesn't look as if it's adequate to support the thing without vibration. It's just some flats welded to the thin gage cabinet, with a pretty healthy overhang inside.
If it's feasible,, I'd sure like to use the stands.
Old 11-26-2018, 02:49 PM
It's a really light machine, and it actually has to be secured TO the floor. Only weighs 1100# plus the cabinets (maybe another 70-100#)
I can run plate under the adj feet, and bolt to that plate.
Remember, I gotta raise the headstock about 1 1/2" to level the thing. Wouldn't be an issue if the thing didn't run all geartrains in an oil bath. Things gotta be level for the right oil flow.
Suppose I could mill riser blocks for the headstock at the required angle, so's the bolt will be plumb to the stands. I can trick the tailstock end for squaring the bolts to the cabinet.
Old 11-26-2018, 03:13 PM
How about a angle Iron frame to set them in?
