![]() I went through all my V belts and had to break down and buy a belt. The 12" pulley I have does not have a set screw, so had to drill and tap for a 1/4-20. Was quite a challenge, as the hub is very close to the outer rim and also had to rig up and extension for drilling the hole. Turned out well. Now have to install the 4 1/2" pulley and tighten up the motor base bolts and give it a test run. Also have not found anywhere to lube the arbor spindle. It turns easily with one finger with no side play. Have not found a manual for it yet either. Hoping the pulley calculator is right on the belt size, if not back to the hardware store for an exchange.
Chris The question isn't who is going to let me; it's who is going to stop me. Last edited by milomilo; 12-27-2020 at 05:07 PM. |
More pics.
Chris The question isn't who is going to let me; it's who is going to stop me. |
Be careful when running that 12" pulley at that speed. At 1740 RPM it works out to almost 5500 SFM which is very fast for a pulley of that size--large spoked pulleys have a habit of coming apart if they are run too fast. The centrifugal load on the rim will be very high. A nick or minute crack will create a weak spot that could cause the rim to explode. If that were to happen at speed the broken pieces could be deadly...
I did spin it by hand with the belt off and it stops at a different place each time so cannot down a heavy end.
This should be your manual, if not look around and you should be able to find it.
Drawing by Smartdraw |
Here is a rpm calculator
I am guessing but it looks like they have a six inch turning a two inch which in your case would give you 5220
Drawing by Smartdraw Last edited by digr; 12-27-2020 at 05:35 PM. |
Chris The question isn't who is going to let me; it's who is going to stop me. Last edited by milomilo; 12-27-2020 at 06:28 PM. |
Why in the world is the pulley on the cutter head so large. My 6" jointer has a 2" one and it never has any problem slipping . Been there for over 40 years and done a lot of cutting.
...lew... Look at the pulley, B , on Pg4 of the manual above . That is about 2" just like mine . That should make the motor one a LOT easier to handle. :-) ..lew.. |
I have a Rockwell like that. Big pulley is appx 7" OD, small one about 3" OD. Can't see the motor RPM offhand as it's stuffed in a corner behind a 2,400 lb vertical mill.
I got it off Craigslist for free, never ran it.
USMCPOP |
