Oxy/propane torches
I don't need them much and haven't needed them for a while so I'm not in a hurry to get a full tank back, but yesterday, I did have a pipe I needed to bend and I was really wishing I had a full tank of acetylene. I was talking to an old friend and he said "Just use propane. Your acetylene regulator will thread right into your BBQ grill tank." I'm like "yeah right." But he was insistent on it so I tried it and sure enough, it did! It looks like a lot of people like using LP instead of acetylene because it's cheaper and easier to fill. I'm liking that idea too! I used propane in my same torch to heat up my pipe and while it took a bit longer than acetylene, it got it plenty red hot enough to make my bend! It sounds like it works even better with a propane tip so I'll be ordering a replacement tip for my torch. If anyone has one they suggest, I'd love to hear it, otherwise I'll do some googling. I had no idea that my BBQ grill tank would thread right into my acetylene regulator, and I could use that instead of acetylene. Maybe someone else here didn't know that as well. |
Gerry is a fan and uses it I use it no real complaints about the only thing you can't do versus acetylene is gas weld.
Kurtis from CEE on YouTube uses oxy- propane for cutting and heating too..
My Dad had both propane and acetylene torches. The propane was cheaper to run and easier to get refilled. The propane was only a tad slower to preheat prior to cutting, but barely noticeably. Raising a burr with a chisel speeds up the initiation of a cut with either system. The thin metal of the burr gets hot enough to start cutting far faster than the edge of the work. Only worth the extra step on thicker material IMHO. YMMV
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. |
The hose is different for propane. I believe it is a T ( model number) hose.
Don't know why, I have just seen use Grade T hose for propane. However, I have seen a piece of garden hose used in a natural gas water heater connection. Scott |
I've been tempted to try drilling a recess in the tip to see if that would stabilize the flame.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
A propane tip will really make a difference. When lighting and adjusting your torch, put the flame against some work or metal and you can add fuel or oxy easily without blowing out the flame.
Propylene is a good option.
I use propane as well. I personally have no reason to go back to acetylene. However, I must caution you - If you do use acetylene again MAKE SURE YOU SWITCH BACK TO AN ACETYLENE TIP. You can use propane in an acetylene tip (albeit poorly) but you cannot use acetylene in a propane tip. DAMHIK.
I have been told you need to use the proper hose for propane, but In 20 years I can't say I have had an issue.
I believe the appropriate metaphor here involves a river of excrement and a Native American water vessel without any means of propulsion. |
I had both before leaving Onterrible, but I also had access to large oxygen tanks to run with the propane.
Out here I only have a small pair of tanks, and use acetylene, partially because I’m still using the same tanks and gas I moved out here. I think I have one or two more b tanks that are still full, at current rate that will last me several years. However, I use them as a last option now. Zip cuts, grinders, and abrasive wheels in my gas concrete saw get used first. Again it’s partially because I have a supply and am still using that up. Sent from my iPhone using Tapatalk |
