Old 03-12-2019, 10:49 AM
Default Maxtron or XMT?
yes the XMT does have a nice lightweight and very portable package..easy to take from the shop out on a job in the back of a pickup and run on either hi or low voltage and single or three phase..
the CP252 will stay in the shop.
Not Enough Room
