Old 05-17-2019, 01:19 PM
wumpus138's Avatar
wumpus138 wumpus138 is offline
Looks a little better than the one I did earlier this week.
I would bet its paper thin where it’s broken and you would be better off putting in some “new” steel
ID:	150798   Click image for larger version
Old 05-18-2019, 04:19 PM
KevinF KevinF is offline
Went and had a closer look. It's still minimum 3/16 where its broken out. I think if it's welded well it should have a reasonable lifespan yet. Thoughts? I'll also check and see what a new one is worth.
Old 05-18-2019, 08:38 PM
I'd just weld it up.
We are losing sight of civility in government and politics. Debate and dialogue is taking a back seat to the politics of destruction and anger and control. Dogma has replaced thoughtful discussion between people of differing views.
Old 05-18-2019, 09:42 PM
Grind the weld areas clean and have at it
Old 05-20-2019, 05:47 AM
Default repair this bucket
for starters it's an extra $100 right off the top before the repair quote because they didn't powerwash it and now I'm gonna be working in shi#
Not Enough Room
Old 05-21-2019, 12:15 PM
Its done. Took 5 hours including lunch. I asked her to pressure wash it before bringing it over and she did. 5lb of 5/32 7018 into it. More stick than I've burned... ever.
It went pretty much like I expected. Bent the bottom plate back into shape so it wasn't under a bunch of stress after welding. Pulled the side in and bottom up with porta power, welded up the corner. I put a lot of weld into that corner to tie everything together. I told them if it starts to crack again beside the welds I'll weld straps across - but be sure to get it to me before its almost in three pieces again.
ID:	150837   Click image for larger version
ID:	150838   Click image for larger version
ID:	150839   Click image for larger version
ID:	150840   Click image for larger version
Old 05-21-2019, 12:24 PM
Five Characters
ID:	150842   Click image for larger version
ID:	150843   Click image for larger version
Old 05-21-2019, 04:22 PM
If you're just going to patch it like that I would then take and fit another 1/4" plate to either the top or bottom and weld it in... then plug weld it down the center... then it should last you a while.
From what I can see where it will fracture again next to the held on either side.
it's just inevitable.
Old 05-21-2019, 10:46 PM
I agree it probably will. New bucket is 1250. If it starts to crack again I can add more steel or she can buy a new one. We'll see how long it lasts.
Old 05-22-2019, 08:03 AM
I have done enough farm repair to know you did the right thing. You say your piece, and recommend a repair plan, and then do exactly what they want.
When it comes back again, they will want it done the way you suggested.
Aaron Neville
