  #41
Old 11-05-2020, 07:35 PM
Norm W's Avatar
Norm W Norm W is offline
There should be another set. It looks like adjustable width hold downs for a mill etc.
  #42
Old 11-05-2020, 09:05 PM
Originally Posted by threepiece View Post
Let’s see if we can come up with a different application, I won’t be using it for that. Perhaps sheet metal forming?
yeah, one could use them for some form of sheet metal bending maybe even weld a small duckbill flange on them or die them up for a certain bend or shape
  #43
Old 11-08-2020, 02:19 AM
The action of this one is a bit difficult to explain.
It looks like a screw driver for slotted screws but for a special application. Both ends are the same. They each have two positions, free to slide and locked against spring pressure. Shown are the two positions on each end.
  #44
Old 11-08-2020, 02:28 AM
I’m still trying to figure this out.
  #45
Old 11-08-2020, 08:36 AM
Almost looks like a tool to drive sheet metal screws that have both 5/16” hex head and straight slotted groove.
  #46
Old 11-10-2020, 12:26 AM
Well the hex measures almost .390 so it doesn’t really engage a 3/8 head properly. Moreover the pin holding the socket to the shaft is small and would not hold up well to a power driving.
This thing looks more like and adjusting tool of sorts.
  #47
Old 11-10-2020, 12:31 AM
This one says True Temper, I suppose the same company that makes garden tools and such. I don’t know what it is.
  #48
Old 11-15-2020, 10:04 PM
This one sounds and acts like a hydraulic device. When I turn the protruding square shaft it is spring loaded in one direction and returns slowly when let go, makings a swishing sound as if liquid passing through an orifice.
I presume this is a door closer but would like someone to confirm.
  #49
Old 11-15-2020, 10:22 PM
Samcord Samcord is offline
Too easy! I just googled 20-330. https://www.doorware.com/site/product.cfm?id=195864
  #50
Old 11-16-2020, 06:53 AM
Originally Posted by Samcord View Post
Screenshot!
