With the amount of energy that is being consumed I expect most people on earth should be living in Utopia. And now this? It started hitting the fan in the 1950's https://m.youtube.com/watch?v=nRnNDkHb0MU A technologically advanced society would teach their children how to start a fire by rubbing two sticks together before teaching them how to use a lighter. If you are not having fun then you are doing it wrong. |
You are welcome to do so if you find yourself in the neighborhood.
I think you mean Barn Find Hunter (episode13)
This thing has become more curious since cleaning it a bit.
I was able to loosen a part. It pivots on a pin and moves about five degrees.
It also has what I would best describe as a micrometer adjustment on on end. It is seized and won’t turn without fussing. Now that I think of it I will later count the number of increments around the barrel.
Yep, still thinking it’s a finger for a tool and cutter grinder myself, the cutter rests on that as the cutter is fed along the grinding wheel. The micrometer adjustment would adjust the height, which is how the slight angle changes are made for the relief angles on the cutter.
The pivoting would allow for fine tuning the location of the rest to get it as close as possible to the edge of the flute as well. Sent from my iPhone using ShopFloorTalk |
I agree a cutter grinder
the finger fits more in the gullet of the flute so you don't grind the finger. once you sharpen the flute you rotate the cutter to the next flute the finger is spring loaded so you can rotate the cutter, it springs over the next flute and springs back under the gullet for the next flute to be sharpened.
manual cutter grinder. http://vintagemachinery.org/pubs/2097/20790.pdf 20.3mb
#29
Some screen shots. Thanks Gwiz! Sent from my iPhone using ShopFloorTalk
#30
That brings back some memories or nightmares. Except that the machine was a Brown and Sharp. Trying to figure out how to mount the cutter at the correct angle, with the correct clearance and consistent blade sharpness was an exercise designed by Rubin Goldberg.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
