Old 01-28-2020, 11:34 PM
Stewartjw321 Stewartjw321 is offline
Default What welder is this please help
Got this guy from yardsale can not figure out what it is.
ID:	154451   Click image for larger version
ID:	154452   Click image for larger version
ID:	154453   Click image for larger version
Old 01-29-2020, 02:28 AM
OZWELDER's Avatar
OZWELDER OZWELDER is offline
A big old AC ( stick welder) 230 volts input. By the colors, I think it could be an old Miller. It is a transformer based machine and that makes it big,heavy and liable to only be reliable for 40 or 50 years when working properly.Also when working properly relatively cheap to run,ie cheaper electrical bill.
Australia where I come from, 230 volt is household supply, but I understand that on your side of the pond its something like 110 volts. The unit is more suited to almost continous working in a big shed with a heavy duty power supply.The local guys will be along shortly and tell you more on that side of it.
Ok! I know nothing of your abilities or skills but it seems to me that if you need to ask, that your electrical knowledge needed to get the unit operational (if that's your intent) might not be sufficient to repair/assemble the pictured machine by yourself with regard to electrical safety.
I can only suggest If you don't know what is what, get qualified electrical help instead of trying to have a go your self.
The live power source in a machine like that is enough to make your very dead and it will likely hurt a lot before you die,if you make an error.
I am not trying to be a smart arse or pick a fight with you but feel compelled to say trying to learn how to assemble the machine via a Forum like this and make it work safely is not a task for amateurs.
At the same time I acknowledge there are many knowledgeable people here on the Shop Floor Talk Forum and I am sure they will advise you not to work on it with out skilled help.
Have a nice day
Ozwelder
Ozwelder
Old 01-29-2020, 02:51 AM
Welcome to the Site.
1) Maybe this thing,
other than that looks like it is made pretty good (assuming it is copper wound).
Old 01-29-2020, 08:15 AM
Banned
Good catch "G".
I have seen that also as a miller, check their website for a manual
"rod runner" or some other name I think.
225 to 295 was a marketing fad, seems everyone figured out how to upsize the winding a wee bit more (or lower the duty cycle) so to match the others.
IIRC century started the
"race to 295"
Old 01-29-2020, 09:13 AM
Norcal Norcal is offline
Have a nice day
Ozwelder
People in the US ignorantly refer to voltages as 110V, or 220V, but they are pre WWII voltages, today standard residential voltage is 120/240V. Then you get into other voltages 120/240V 3Ø, 208Y/120V, 480Y/277V. The only ones still using 110V are the Brits with their building site transformers, & each leg is 55V, to run 110V portable power tools.
Old 01-29-2020, 12:19 PM
110/ 120= same thing in my book. I was taught in school that AC voltages tolerances were +- 10%, so it’s right in the ballpark.
But I better state this, I am not a licensed electrician, I just act as though I am one sometimes.
Old 01-29-2020, 12:51 PM
Banned
Who cares ?
How does this little rant of yours actually help or contribute to the OP's question ?
Old 01-29-2020, 01:11 PM
Who cares ?
Nothing wrong with a little more information, also helps keep the reply/post count up something SFT needs.
Old 02-05-2020, 12:04 PM
racer-john racer-john is offline
Yep, you got that right!!!!
Lathe Grizzly 9 x 19, Century 110V Mig welder, O/A welder, hammers, dollies, 10 speed Drill Press, multi drills, grinders, both corded and 20v battery.
Old 02-05-2020, 12:18 PM
Banned
It wasn't really doing that, more it was arguing a moot point, and cornfusing several.
