Old 05-11-2008, 03:20 PM
dichdoc dichdoc is offline
Default Cable reels finished
Finished up some cable reels for the soon to come welding flatbed. Here's some pics and a pdf of the sketch. The reels are 15" circles and a 15" piece of 1 1/4" pipe with bearings ove a 3/4" CRS round bar. The reels are not wired there is a partial chain link that the wire will hook under and then roll them up. I tried to come up with a "fancy" locking mechanism to keep them from unrolling but opted for two pieces of black rubber bungee with the slots for adjustablity and just stretch it over the handles locking them together. I also plan to cover the whole works under a vinyl bag. I had the diamond plate steel and 2x3 tube and 1/4" plate had to buy the pipe and 3/4" bar and all hardware totaling around $75.00 TB
Name:	WELDER REEL (644 x 483).jpg
ID:	31730   Click image for larger version
Name:	WELDER REEL 2 (644 x 483).jpg
ID:	31731   Click image for larger version
Name:	WELDER REEL 3 (644 x 483).jpg
Millermatic Passport plus and spool gun
Millermatic 250
Miller Bobcat 250
Hypertherm 65
PlasmaCam 98z
Enco 7x12 bandsaw
Delta Industrial 16 1/2" Drill press
Lincoln precision Tig 275
Old 05-11-2008, 03:41 PM
jksweld's Avatar
jksweld jksweld is offline
Them look purty dich
on my reels I welded a piece of 1/4" x 1" to the sq tube and drilled holes on the sides of the reels and uses hitch pins to keep them from unrolling
one thing that I see that may cause a problem is the small diamiter of the pipe and the leads been coiled to tight around that small of a radius, it may be all right though.
what is the other 2 reels for ext. cord and hose? and how do you plan to hook them up?
Great work
Name:	camera pictures 388.jpg
SAGO MINE TRAGEDY
WE WILL NEVER FORGET
1-2-06
Old 05-11-2008, 03:50 PM
Looks good, Travis but I'm with James - wondering about that hub diameter.
Old 05-11-2008, 04:54 PM
At this point the other two are for a regular extension cord and extension leads. I'm just going to unroll them all the way and plug them in with the twist locks. Not ideal but couldn't come up with a clean easy, cheap way to leave them connected and most of my mobile work requires all my leads and then some. I thought about the small diameter too but leads seemed to wrap fine are you worried about damaging the leads over time by wrapping them that small? TB
Millermatic 250
Miller Bobcat 250
Hypertherm 65
PlasmaCam 98z
Enco 7x12 bandsaw
Old 05-12-2008, 06:48 AM
randydupree's Avatar
Why, Hell Yes!
i made a big air hose reel and i ran the end of the hose out through the center pipe and the hose sticks out so you can hook it to another air hose,the air hose coupler will swivelon a lead you just unhook the lead to roll it up.
Randy
Old 05-12-2008, 11:30 PM
jksweld's Avatar
yes, I think over time of been wraped around the small diamater that the strands will eventually break or weaken
SAGO MINE TRAGEDY
1-2-06
Old 05-12-2008, 11:39 PM
I'm picturing something kinda like a big telephone handset cord, especially down towards the inside of the coil.
Old 05-13-2008, 12:11 PM
jniolon jniolon is offline
yall tell me if I'm full of it...
how much does 1 or 200 feet of welding lead weigh ??? 100 # ??? will 3/4 rod hold that much weight plus the reel weight and not bend ??
seems like a weak point to me... but the reels sure are nice. Nice fab work dich..
john
Old 05-13-2008, 03:35 PM
getatorch's Avatar
Tuned-Up Big Builder
Very clean looking work there! As time and use goes on modifications can always be done if needed.
Old 05-14-2008, 04:45 PM
comp comp is offline
john
i didn't think about the weigh
