Old 05-04-2007, 08:18 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Default indicating on threads?
Sometimes I have to cut a already threaded piece in the lathe(stepped threads usually) If its too big for a collet it makes it difficult to indicate in the chuck being there is no smooth surface. I have always just clamped a piece of sheet metal so its perpendicular to the ways and rubbing against the piece, then placed the indicator on top of the sheetmetal. Not perfect by any means but it gets it pretty close.
I am sure there is a better way?
Old 05-05-2007, 06:48 AM
Setup boy's Avatar
Setup boy Setup boy is offline
Press One for Trash
I am not so sure I know what you trying to do but if I take your thread lead "indicating on threads" and go with it I am assuming that you are trying to find the center of a threaded hole. If that is the case I would find a shoulder bolt screw with the same size thread and run that down flush and indicate the body of that. If you don't have them find a dowel pin, drill rod or turn down some round stock and put that in the threaded hole and indicate that depending upon the depth of thread concerning rigidity. But from the description you gave of what you wanted to do I think I might have wasted five minutes of my life that I will never get back because I assumed. Uhhh....did this help?
Thank you,
Tom(Reformed Post Whore)
This legislation will have the effect of addressing that mal-distribution of income in America."
Sen. Max Baucus Montana
Do you want it right or right now?
Ya can't polish a turd.
The Techie Geek Podcast
Old 05-05-2007, 07:57 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
From your description I don't have a clue. Just describe what you want to do and I might be able to explain several ways to do it.
Old 05-05-2007, 08:06 AM
Cavalry's Avatar
Below Wholesale
sorry boys...that was vague, even for me. 17hrs is too long a day for anyone. Hopefully its more coherent now
Old 05-05-2007, 08:18 AM
moe1942's Avatar
Voice of Experience
For starters if you are chucking on the threads you are pissing into the wind. You will never accurately indicate the rod. I have to assume you are doing this in a four law. If so, a three jaw will provide accurate enough results on threaded rod.
A little trick I use so I don't clamp down on the threads: get two nuts of that size and make one narrow kerf cut across one flat on each. Thread on the rod so one nut is in the back and one in the front of the jaws. This will allow you to get a more accurate set up of threaded rod.
If you still are bent on indicating I will add more.
Old 05-05-2007, 08:39 AM
Roundrocktom's Avatar
Roundrocktom Roundrocktom is offline
Cav -- photos help.
Moe -- you wouldn't have have an automatic screw mache for threading? I need about a 100 plugs. 14mm x 1.5m thread with two stepped ends.
Make 'em one at time out of 6061T6. Not bad when you get a rhythm going, but gets old after the first 10. Rough, finish, two steps, thread, part.... repeat. 3 jaw chuck, need to build a feedbar someday.
Tom
Old 05-05-2007, 09:09 AM
moe1942's Avatar
Voice of Experience
Originally Posted by Roundrocktom
Cav -- photos help.
Tom
Sure don't tom. Don't do much machine work anymore. Just what I need done around the ranch.
I'll bet precisionworks (Barry) could fix you up. Don't see much of him anymore. Mostly I see him at a machining site I go to. If you are interested in asking him I'll give him a heads up..
Moe
Old 05-05-2007, 09:16 AM
Moe
No need to bug Barry. 100 pc is small job for commercial outfits.
Which machining site?
Tom
Old 05-05-2007, 09:22 AM
moe1942's Avatar
Voice of Experience
Here's the site Tom. Pretty good info some times.
http://www.practicalmachinist.com/cg...ultimatebb.cgi
Old 05-05-2007, 11:55 AM
I am not to sure what we are talking about here but to indicate a threaded rod you could machine a "round" nut and indicate off of that. I think I know what you are talking about with the sheet metal riding on the threads.
