Old 11-01-2011, 09:54 PM
Default Feed lever
For reasons I rather not get into, I broke the feed engagement lever on my Sheldon lathe, I didn't realize that the shaft and cam were one piece, made of cast iron. First I had to remove the apron take it apart and measure the shaft and cam, then put it back together and make a new one.
1-2 old part
3 Milled a square piece to the thickness and bored and reamed to 3/4"
4 Milled the 3/8" slots
5 Shaft turned to 1" and the end turned for a press fit into the new cam
ID:	83389   Click image for larger version
ID:	83390   Click image for larger version
ID:	83391   Click image for larger version
ID:	83392   Click image for larger version
Old 11-01-2011, 10:00 PM
6 shaft pressed in
7 Chucked in the lathe and the profile turned
8 Old one in the rotary table to indicate the hole for the stop pin
9 Drilled for new pin
10 Just about there
ID:	83394   Click image for larger version
ID:	83395   Click image for larger version
ID:	83396   Click image for larger version
ID:	83397   Click image for larger version
Old 11-01-2011, 10:10 PM
11 Indicating hole for detent
12 Detent done
13 Test fit
14 put a key way with two set screws instead of the original tapered pin
15 all done
ID:	83399   Click image for larger version
ID:	83400   Click image for larger version
ID:	83401   Click image for larger version
ID:	83402   Click image for larger version
Old 11-02-2011, 05:46 AM
nctox's Avatar
nctox nctox is offline
SFT Navigator
Thanks Digr. That was really a good tutorial. I won't even push for how you broke it.
When turning a piece of stock with 4 corners, like a square or rectangle, do you mill or saw the corners off a little before turning it to size? I'm always concerned that I'll break off the cutting tool, otherwise.
Trying to make retirement as much fun as 40 years of working
So far,,,I'm succeeding.
"I don't care if you like me or not. I'm not even on Facebook."
Old 11-02-2011, 06:06 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
NC, I turned a couple of squares round and used high speed steel tooling instead of carbide, it takes the shock loading of an interrupted cut better that carbide does.
Digr, nice work as always.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 11-02-2011, 07:31 AM
nctox's Avatar
SFT Navigator
Dan.
Thanks Dan. I'll try HSS tools. I've got a few of various sizes.
Old 11-02-2011, 07:36 AM
JH35's Avatar
JH35 JH35 is offline
+1 on HSS. You're not trying to set a land speed record anyway and interrupted cuts aren't kind to tooling.
Jeff
Curator of the canned cycles.
Old 11-02-2011, 08:35 AM
I normally try to avoid turning square things round in the lathe I just root around in the scrap box for a chunk of defective pipe.
If the part is not too thick and I can lay it out on a large enough surface I sometimes cut the excess away by plunging with a parting tool.
In this case there is a mill available so those corners would be gone before it hit the lathe.
Old 11-02-2011, 09:22 AM
Nice work. Wish I had your skills and equipment.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 11-02-2011, 10:59 AM
Charlie C's Avatar
Charlie C Charlie C is offline
More STEAM!!
Very nice work. I will even second or third the HSS.
