Old 08-15-2010, 08:00 PM
Default Powermatic 1150 Drill Press Rebuilt/Modification
A couple of weeks ago, I posted that i picked up a Powermatic model 1150 variable speed drill press, or pieces of a drill press. So I started to clean it up, and determine the course of action to make it run. I had a 3/4 hp, 1725 rpm motor off of a Jet drill press. After reading the manual, I found out the minimum speed was in the 450-500 rpm range, way too fast for what I need, so I decided to adapt a layshaft configuration to the DP that will offer 4 main speed ranges, with the variable speed part usable within those ranges. So I started to fab up the necessary pieces. Being real cheap, I dug thru all of the machine parts I have and found 2 matching 4 groove pulleys, but the were the wrong bore. I bored out the bores and pressed in an aluminum slug, then rebored the pulleys to the required 3/4" bore. The bearing should be here this week and this should be running. Then the variable speed controls, will have to be fabbed.
ID:	64419   Click image for larger version
Name:	powermatic 1150 002x.jpg
ID:	64420   Click image for larger version
Name:	powermatic 1150 005x.jpg
ID:	64421   Click image for larger version
Name:	powermatic 1150 011x.jpg
Old 08-15-2010, 08:24 PM
cutter cutter is online now
Hmmm, so what are you shooting at for the bottom speed range, Jack?
Old 08-15-2010, 08:46 PM
Cutter,
If my pondering and ciphering is correct (fingers times toes, divided by scars), it think it will be in the 150-175 rpm range, more usable for what I need. Thats if a man needs 6 drill presses.
Old 08-15-2010, 11:26 PM
Vernon's Avatar
Vernon Vernon is offline
Default Drill
Looks great I need to slow my drill down. Would like to see yours when you get it all done. I will check it out.
Vernon
Due to the lack of effort today Tomorrow has been canceled...................
Old 08-15-2010, 11:35 PM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
the two big pulleys on the original drill are basically a cvt transmission right?
cool project
Old 08-15-2010, 11:51 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
I don't know about your need for six, but this one will be nice. Jerry
Old 08-16-2010, 06:02 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Jack, the I by looking at the step pulleys you are using I think you low speed will be lower then you are estimating. I would guess the 100 to 125rpm range.
I looked at a industrial radial arm drill press last week on my way home from work, I think the lowest speed on that was 25rpm, I might buy it from the guy when the new shop is up, as it is too big for my present shop.
Interesting project, keep the photos coming.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 08-16-2010, 06:18 AM
JohnBoy's Avatar
Another obvious question.....
But is there any such thing as too slow?
Old 08-16-2010, 09:12 AM
DrBob's Avatar
DrBob DrBob is offline
Default S l o o o w
Dan.
Wow! I wonder how big a drill bit that thing will take?
Nice Project, Jack!
DrBob
Old 08-16-2010, 10:10 AM
Lu47Dan's Avatar
Nice Project, Jack!
DrBob
DrBob, it was a Fosdick, I think he has up to a 3" drill bit for it, he moved it from his grandfathers shop and is thinking of selling it next summer. I worked with him on my last job and he asked me if I would be interested in it once he has finished the project he is working on. I would have to get a bigger trailer to haul it home on as he says it weighs over 5000lbs. Not necessarily something I would use everyday but handy to have when you need it.
Dan
Hobart 175 Mig
Craftsman O/A set
