Old 02-27-2019, 07:28 PM
Default Welder Upgrade
I picked up an Allmand 180 amp AC welder yesterday with two 220v extension cords. The weld leads were all cracked and not repairable. It was free to me.
Replaced the weld leads with some good ones I had picked up over the years. Rod holder needed some work, Ground clamp was shot. Replaced the rod holder and the clamp. The plug ins on the front of the welder were unique so have to salvage them, soldered in the old ends to the new cables.
Plugged it all back in and ran a bead with 5/32 6011 and it ran pretty damned good for being 15F outside. The outer shell had been repainted so no numbers to select amps. Guessed on the amp selection and it was real close. I will put it up for sale on her local FB trading post account.
ID:	149621   Click image for larger version
ID:	149622   Click image for larger version
ID:	149623   Click image for larger version
Old 02-28-2019, 03:56 AM
I tried looking up the face plate for that machine and can't find one like it what year was it made found a craftsman looks a little like it and a Forney that was somewhat close but power switches were on the left side, not center was that industrial grade for its time?
Old 02-28-2019, 08:00 AM
chumly2071's Avatar
Urban Gunfighter
I found a thread on weldingweb where a guy had one, looked to be a bit older. No real info, as he was asking the same question about the taps.
You might try calling Allmand. They are still in business, making light units and small TLBs. We used to supply backhoe assemblies for them.
They got bought out by Briggs and Stratton, apparently.
contact number for customer service. 1-800-562-1373
Old 02-28-2019, 04:33 PM
The one pictured here has what appear to be the old markings. 2-9 and the three taps S, G and C. (solder, ground, cutting?)
https://weldingweb.com/showthread.ph...Allmand-welder
Name:	allmand 180 welder 1.jpg
ID:	149633   Click image for larger version
Name:	allmand 180 welder 2.jpg
ID:	149634   Click image for larger version
Name:	allmand 180 welder 3.jpg
Old 02-28-2019, 05:47 PM
Thanks Pop. I guessed and used the center tap when I did the weld. Just got lucky I guess. Maybe those 3 are still grounds????? but give you a different range?????
Old 03-04-2019, 07:21 PM
Chris. Maybe, more like different polarity +/- and or High and Low amp tap setteing.
Old 03-04-2019, 08:28 PM
AC machine, so no polarity options. Soon as the weather changes and the snow melts off I will test out the 3 lower taps and see if they are low, medium and high as I expect.
Old 03-10-2019, 12:54 PM
monckywrench's Avatar
trust but verify
Cool score. The nice thing about tapped machines is no rotary switch to stick/break.
Before I had a lathe I cut down a couple of cylindrical modern cable ends to fit tapered sockets on an old Hobart TIG by chucking the brass in a hand drill then spinning it against a flap disc on an angle grinder. Ghetto but works fairly well.
Old 03-10-2019, 07:46 PM
I did the same thing with copper a few years back and I had a lathe at that time, but this method seemed much faster, and it was too. Sometimes ghetto is the right way to go.
Old 06-16-2019, 11:03 PM
Sold the free welder today for $100. Kept one of the long 220V extension cords.
