Old 04-23-2019, 09:00 PM
OldRedFord's Avatar
Kibble King
Default Buying round bar
Where are good places to buy round bar. Mild steel and up to 2" diameter. I want some pieces to play with and also need to remake a vise screw.
Tim
Old 04-23-2019, 09:19 PM
Do you know anyone running a crushing spread, where ever there are crushers and conveyors running there will be used and abused shafting laying around.
Old 04-23-2019, 10:25 PM
One place to go is to a shaft and tube supplier. They will always have drops from cutting to order. I got a 45 gallon drum full of DOM drops for $300, for example. Scrapyards are another source of hot and cold ground shafting.
Old 04-24-2019, 01:40 PM
I get most of mine from auctions.
Old 04-24-2019, 04:16 PM
Rob65 Rob65 is offline
ORF,
Have you got any hydraulic cylinder repair shops near you?
If so ask if you can have a look in their scrap. Plenty of round stuff will be waiting for you to re-home it
Rob
Old 04-24-2019, 11:06 PM
LKeithR LKeithR is online now
Originally Posted by Rob65 View Post
...Have you got any hydraulic cylinder repair shops near you?
If so ask if you can have a look in their scrap. Plenty of round stuff will be waiting for you to re-home it...
There are two main types of cylinder shafting; CPO, short for Chrome and Polish Only; and IHCP (Induction Hardened and Chrome Plated). CPO is usually 1045 shafting which is excellent to machine. IHCP is most often 4140/4340 (which is also fine to machine) but it has a hardened outer skin .050"-.060" thick which is very tough and almost unmachinable. If your lathe is solid enough to peel off .080"-.100" in one pass it's not bad to work with once you get past that first layer.
If you're looking at used chromed shafting take a hammer with you and give each piece a light tap. It doesn't take much to put a little dent in CPO but you've got to whack IHCP pretty solidly to make a mark. If you have a piece of both you'll quickly see the difference...
Old 04-25-2019, 08:21 AM
OldRedFord's Avatar
Kibble King
I don't know why I didn't think about it before but I think truck axle shafts would work too. The junk yard I got some steel beams from a month ago sells pull yourself auto parts at $0.25 a lb.
Tim
Old 04-28-2019, 06:00 AM
jatt jatt is offline
Would that only be hardened on each end ie spline and bearing journal?
Old 04-28-2019, 11:46 AM
Truck axles aren't so much hard as they are tough. They're designed to take high torsional loads without yielding--somewhat like a spring. You really have to torque them up before they'll actually twist. They're generally tough to machine and, of course they're unknownium so they're useless for most projects...
Old 04-29-2019, 02:20 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
If you just got to have it and can't find it anywhere else, www.Metalsdepot.com can help. I found them cheaper than other online sellers.
Dave
