Old 04-03-2019, 06:07 PM
platypus20 platypus20 is online now
Default Today, I Lost Another Drill Doctor
After doing tens of thousands drill bit resharpenings, my trusty Drill Doctor 750X, today decided it had reached its expiration date. The loss was a great catastrophe, it had served me loyally for about 5 years, it set idle on the shelf for weeks, then in a mad rush, resharpen a couple of hundred bits, then the cycle would repeat.
The motor still runs perfectly, the pivoting mechanism for the sharpening chuck, is completely shot. So I went on a search and acquire mission, my local HD, only had the base unit, but Lowe’s had the middle model, not what I really wanted, but it will suffice, until I can either find a better on or I break down and buy an industrial grade Darex.
I did about 30 drills this late afternoon, the unit works fine. I’m somewhat pissed, the trash collection was this morning, the dead unit, could be in the landfill by now.
Old 04-03-2019, 07:59 PM
Its about time that you learned to sharpen bits by hand
Old 04-03-2019, 08:58 PM
What?
was it this thing on eBay for about $12.00 ?
They were about $3.50 I guess they went up in price.
Old 04-03-2019, 09:19 PM
What?
That's what I was wondering.
Old 04-03-2019, 10:49 PM
Here are two cheap and nifty ideas for sharpening bits... I think if someone took a little more time on the right wheel, you could get a good sharpening on one.
https://www.youtube.com/watch?v=1Ld6pqVF-NY
https://www.youtube.com/watch?v=p818cZI7E94
Old 04-03-2019, 10:55 PM
You are as hard on your equipment as you are on your minions.
Old 04-04-2019, 07:34 AM
Platypi are "venomous".....
But I didn't think it would dissolve plastic....
Old 04-04-2019, 08:54 AM
He has never admitted to throwing a minion into the garbage yet, but we do have this admission:
so the poor thing wore out, failed and was ungratefully mistreated
Old 04-04-2019, 10:01 AM
I do it all the time, I can get a drill bit to drill a hole, but not without an egg shaped hole or wandering holes. For about 75-80% of what I do I need accurate holes, so I can tap them or line up with the other parts, in the assembly.
The Drill Doctor worked perfectly and until yesterday, I never had an issue with it.
The best drill bit sharpener is ever used was at my grandfather’s machine shop, it was made in the early 1900s, I believe the name on the side was Simpson or Simplex, it was quick, accurate and easy to use.
Old 04-04-2019, 10:08 AM
That's why I never bought a DD...all that plastic.
How about the one Grizzly sells ?
IIRC it had a couple of rows of collets on top, and 2 stations,
one on each end.
Looked to be all metal construction.
https://www.grizzly.com/products/Gri...-Machine/H8203
