Old 04-19-2010, 08:56 PM
Default Blade Question
Since I retired I put the word out that I would take a little work in to help pay for our yearly vacation. So now I have jobs piled outside the door. This is one of them. Its a blade off of a John Deere excavator. It had two added layers plus the factory layer, each worse than the one before. This blade had a cutting edge scabbed on it. Do you think this blade needs a cutting edge? I haven't had time to run down to John Deere to take a look at one if the have one there. When new do they come with a cutting edge? The owner says they only use it for stabilizing the machine and buck the material against when cleaning up. Thats how this one got tore up, I am going to replace it with 3/8" Tribraze plate. (hardened plate roiled with a brake at a local machine shop)Thats it for now.
1 side
2 front
3 layers
4 gone
ID:	60038   Click image for larger version
ID:	60039   Click image for larger version
ID:	60040   Click image for larger version
Old 04-19-2010, 10:14 PM
My mini ex just had a mild steel bar for a cutting edge, though I have to rebuild it (broke out in the back where the cylinder attaches) in the next week or so too.
Old 04-20-2010, 11:58 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Digr, the ones I have seen have a "cutting" edge on them, I would say that they are more of a wear bar then a true cutting edge. I see them being used to grade, back fill, and crowd the material for loading the excess. I would add a strip of steel to save the frame of the blade.
I looked at buying a mini that the blade was worn down into the frame of blade. To the fix it it would have been about $300 worth of materials, with what he wanted for the mini and the general shape of it, it would not have been worth spending the money on it to fix the blade.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 04-20-2010, 05:27 PM
I don't know what model this but I don't think its called a mini, the arms are 2 1/2" thick and the blade is over 8 feet wide.
Old 04-20-2010, 05:59 PM
dirtdigger's Avatar
dirtdigger dirtdigger is offline
Big Shovel
digr,
most blades that size on a JD excavator are just welded on, instead of a replaceable bolt on cutting edge. Looks like you have the right idea of putting a NEW rolled face on the blade. I would weld on a cutting edge or some hardened steel of some sort. Those blades are not made to be used as bulldozers (neither are the final drives) but they get used just as hard.
don't ask me how I know..........
I used to get in trouble for playing in the mud...........now I get paid for it!
Old 04-15-2019, 05:40 PM
Evidently I never finished this post, when the owner looked at the bill he was a little shocked, I thought that i had seen the last of him but today he brought another one from a different machine, a little bigger with the same problem. And of coarse I have forgotten what I had used on the first one. Luckily I still had the bill, and I was a little shocked. Looks like I used 3/8" Tri braze steel for the blade. He said that the first one I did looks like new yet.
1 front 8'6". long
2 back
3 arms 3" thick arms going to 8" aq. tube
ID:	150371   Click image for larger version
ID:	150372   Click image for larger version
Old 04-15-2019, 07:35 PM
Do good work and they will usually come back.
Old 04-16-2019, 04:05 AM
A blade that wide would probably put it in the 8-10 ton range--definitely not a mini.
We've repaired blades in similar condition to that one. In fact, looking at the date of your original post we probably had one on the go at about the same time. If the new plates were just scabbed on they're usually not too bad to remove but if they did a "good" job of welding them on it can be a bitch to remove them can't it? We always put a good cutting edge on anything like that if we fix it. The cutting edge takes the wear and protects the shell of the blade or bucket--it's basically a sacrificial element. If they're replaced at the right time in their life they work well; the problem is that most people don't replace them till the wear is into the actual bucket or blade and then you're faced with replacing parts of the shell before you even put on a new edge.
Yup, that's been our mantra for a lot of years. Build or fix something right the first time and it will last a lot longer. We've had more than one customer go away a little pissed because they thought we ripped them off but 3-4 years later when they realize that their machine or tool is still working like it should they suddenly understand the value of doing it right the first time...
Old 04-16-2019, 01:21 PM
Got most of the rapper off and rolled over and the bottom is in fine shape, very good welds on this and it is very hard to find the seem, plus the rapper was stitched from the inside
ID:	150394   Click image for larger version
Old 04-16-2019, 01:24 PM
I weighed this blade with my scale one halve at a time with one end on the floor and came up with1170 pounds, how accurate would that be do you think?
ID:	150396   Click image for larger version
