Old 08-04-2019, 07:46 PM
Pontiac Freak Pontiac Freak is offline
Default New Welding Table Top
Decided the 3/8" warped plate wasn't going to cut it anymore so I did one from 1" plate. Drilled 49 holes in it and really liked the design. I decided to build another one with 112 holes and sell the 49 hole design. Both were 48x48" after I sent them through the water jet process.
Name:	49 Hole Top -0 (Medium).jpg
ID:	151704   Click image for larger version
Name:	49 Hole Top -1 (Medium).jpg
ID:	151705   Click image for larger version
Name:	49 Hole Top -2 (Medium).jpg
ID:	151706   Click image for larger version
Name:	49 Hole Top -3 (Medium).jpg
Old 08-04-2019, 07:48 PM
Here is the second design that I did. I kept this one and really like it so far.
Name:	112 Hole Top -1 (Medium).jpg
ID:	151708   Click image for larger version
Name:	112 Hole Top -2 (Medium).jpg
ID:	151709   Click image for larger version
Name:	112 Hole Top -3 (Medium).jpg
ID:	151710   Click image for larger version
Name:	112 Hole Top -4 (Medium).jpg
ID:	151711   Click image for larger version
Name:	112 Hole Top -6 (Medium).jpg
Old 08-04-2019, 08:32 PM
Scratch Scratch is offline
Nice! I have a 4'x6' piece of 1" steel for my fab table and want to drill it out with 5/8" holes too, but it has a good sized bend in it and I'm not sure if I should just get another top or not...
What size holes did you go with?
Old 08-04-2019, 08:36 PM
jniolon jniolon is offline
bet you created a pile of dross !!! nice top
j
...my truck project has turned into a road queen !!
Old 08-05-2019, 05:26 AM
I drilled 5/8" holes. How bad is the bend? Could you have it heat treated and ground cost efficiently?
Old 08-05-2019, 05:40 AM
j
This was the 49 hole cleanup
Old 08-05-2019, 08:10 AM
I'm going to ask it. Why the holes?
I have a 4x8x1" table which has holes for a vice, and that's it for the last 25 years. I guess it would let the berries and slag chips fall through, but I sweep them off.
Then I thought hold down things? nah, I tack weld to the table and grind the bump off after.
Old 08-05-2019, 08:14 AM
platypus20's Avatar
Boiler God
I'm going to ask it. Why the holes? Then I thought hold down things? nah, I tack weld to the table and grind the bump off after.
Crude Bastard!!..............................
jack
Old 08-05-2019, 08:28 AM
I'll admit it. It's not a lathe, it's welding.
Oh dear, there's a 1/16" gap at that joint There will now be 100% penetration.
Old 08-05-2019, 08:50 AM
platypus20's Avatar
Boiler God
I have a couple of the Wilton welding clamps, where you weld the shoe to the plate, use the clamp, then cut the shoe off and buff up the plate, when your done with it.
jack
