Old 11-13-2010, 11:21 AM
Pat's Avatar
Pat Pat is offline
Default Making a Machete
A few weeks ago I bought a machete to do battle with some weeds and an unbelievable amount of grape vines. I figured that for $54.00 the over expensive knife should have whacked a vine without loosing pieces of the cutting edge. If that was not bad enough, after getting frustrated that I lost most of the cutting edge in the most used section of the blade, and just smashing the vines, I hit a vine with the blade somewhat sideways and broke it.
I would like to make my own if someone would be kind enough to tell me what type of steel I could get that will hold an edge when I sharpen it, and not crack. I wonder if quality control had the day off when mine was made, and the metal used for the blade was way too brittle. I used to have a machete that I bought at an Army Navy Surplus that lasted for years, and had very minor nicks in the blade. Unfortunately that one walked off about the same time my brother in-law who was living with us was told to find a new residence. Any ideas for material would be greatly appreciated.......thanks.
Old 11-13-2010, 11:29 AM
CEC's Avatar
CEC CEC is offline
Over the Top
Pat,
I've got to agree with you on the quality of machetes today. I made one years ago from a knife blade that they use to use to cut sheet rock (wall board) to size. That one also walked away. I've got one more piece that I hope to make a new one with one day. Don't know the material but it would hold a good edge.
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark -
Old 11-13-2010, 11:39 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Buy a 2" X 24" commercial hacksaw blade. Grind the untoothed edge to a utility blade angle and leave the teeth on it too for sawing. Makes a hell of a bush knife.
redfarm
Guest
Posts: n/a
this may help
http://www.plasmaspider.com/viewtopi...&hilit=machete
Old 11-13-2010, 11:45 AM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
A cheap route would be to use an Old leaf Spring.
You'll have a battle with Heat Treatment and such since technically you would need a Forge the size of the Blade but if you get the Spring for free it's worth a shot just for the fun of it and you could try a Po' man's heat treatment with an O/A set and a BBQ or Fire.
You'll have to anneal it first to be able to cut & shape it- build a big raging fire and put the Spring in it- gonna be tough as you really need to get it Red Hot and then just leave it in there until the fire goes out.
A Rose bud could work also.
Should be able to hammer it flat at this point and then cut out the Profile you want. Grind the cutting edge to your liking.
Then you'll need to heat it up again and quench it.
Then on to tempering.
Anvilfire probably has some directions.
or just buy a known quality Machete
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
Old 11-13-2010, 12:02 PM
monckywrench's Avatar
trust but verify
I just took a grinder to old lawn mower blades and welded a pipe handle to 'em.
Now I use Roundup instead so I don't have to work as hard.
Old 11-13-2010, 12:03 PM
kbs2244 kbs2244 is offline
I don’t know how it was made but I spent many hot hours with one made out a spring.
It still had the curve in it with a bit of a bend at the handle.
Sharpened on both edges.
You could use it in either hand and get close to the ground because of the curve.
Old 11-13-2010, 12:16 PM
Pat's Avatar
Pat Pat is offline
Moe,
If the blade you mentioned is one of them used in something like an industrial power hacksaw, I know where to get some free ones. I will visit my brother. The power hacksaw he has looks like it came over on the Mayflower, and is a very heavy saw. It may be slow but I have seen that thing cut through some pretty thick materials.............thanks to all
Old 11-13-2010, 12:24 PM
I understand that the Tramontina machetes from Brazil are good, though not terribly thick. They seem to sell for $5-$8.. I have one with a copper-wrapped wood handle but haven't put it to the test. I do have a couple Tramontina hammers that I like (not soft).
http://www.dpciwholesale.com/cart.ph...roduct_id=1207
I bet a genuine John Deere lawn mower blade would be good steel. Most any leaf spring should do.
I'll sell you a hand-forged Thai spring steel machete for $8. plus postage. The straight or concave-curved ones are good on brush, especially the latter.
Old 11-13-2010, 12:52 PM
moe1942's Avatar
Voice of Experience
Originally Posted by Pat View Post
Moe,
That's it Pat. Smaller blades make one hell of a butcher knife..and the teeth are very handy, especially on a brush blade..
I have a Stihl commercial weed eater that will take a 8" inch brush blade. Removes the sweat factor..
