  #31
Old 06-14-2018, 02:02 AM
Gadgeteer's Avatar
Smile
OK, now I am officially pissed!!! Went out to the shop this afternoon to take out the power switch. Pushed the forward, off and reverse several times and now it works smoothly every time. I was so looking forward to a drum switch.
Now calm down... just get a drum switch, and wire it parallel to the existing switch. Then, you will have the best of both worlds.
  #32
Old 06-14-2018, 07:46 AM
How will wiring it parallel be an advantage?
  #33
Old 06-14-2018, 09:12 AM
Samcord Samcord is offline
There are better ways to make a smoke machine.
  #34
Old 06-14-2018, 07:56 PM
Gadgeteer's Avatar
Please explain further, as to why wiring in parallel wouldn't work. Thanks.
  #35
Old 06-14-2018, 08:03 PM
Gadgeteer's Avatar
Well, you appeared really upset that the original switch was working, again, so it dissuaded you from replacing it with a drum switch. I'm just trying to make you happy by suggesting you go ahead and get that drum switch, and wire it, so you can use whichever switch makes you happiest.
Of course for safety sake you will have to determine a method that allows you to make sure you are forced to use one switch or the other, and not both at the same time.
  #36
Old 06-15-2018, 05:20 AM
Just seems like putting one switch in forward and the other in reverse would produce a lot of light, heat, and smoke.
  #37
Old 06-15-2018, 09:36 AM
Yup, just like opening up the box and crossing a couple wires...
  #38
Old 06-15-2018, 11:11 AM
I understand what you meant now. LW is checking on a drum switch for me. If he has it I will install the drum switch and disconnect the push button switch. Not sure how I will cover the hole on the cover yet. Likely just cut out a plate and pop rivet it in. Unlikely will find paint to match. Maybe add a bracket for some tools???
  #39
Old 06-15-2018, 11:47 AM
...Not sure how I will cover the hole on the cover yet. Likely just cut out a plate and pop rivet it in...
There are lots of "press-in" hole covers out there--you should be able to find something online...
  #40
Old 06-15-2018, 02:54 PM
I was thinking a bracket for my digital calipers so they are handy up front.
