  #501
Old 08-28-2018, 08:25 PM
Originally Posted by Bender View Post
That surprises me.
Why wouldn't the footings be poured with the slab?
  #502
Old 08-28-2018, 10:10 PM
4-13-1949 to 5-21-2023
That is the way I had my wood shop done. No cracks after 10 years.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
  #503
Old 08-28-2018, 10:58 PM
It's commonly done, especially with steel prefabs.
It is called a floating slab, I think.
  #504
Old 08-28-2018, 11:04 PM
I’ve done a couple small jobs where we had builder’s tubes in place for load bearing supports, that were poured at the same time as the slab. It does require some prepwork, works well though when done
  #505
Old 08-29-2018, 12:23 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
I guess I never thought of a thickened edge as a footing.
I'm envisioning a footing higher then the slab.
Boise Paint Contractor
Facebook
How fortunate we are!
  #506
Old 08-29-2018, 03:53 PM
randydupree's Avatar
Why, Hell Yes!
Its very common down here,we call it a monolithic slab.
But i would have very big,wide and thick places under the building supports.
We have a very big need for that,we call it uplift.
Hurricanes are no joke.
In Fl a friend was building a steel building and code was for like a 6x6x6 foot footer under each post,with the bottom compacted to a certain spec.
They had an inspector on site testing each hole and the bottom of the footers.
I had never seen that before.
I watched a log home eing build and they had a big post in the middle of the great room,it was required to have a 4x4x4foot block of cement poured around the post,for uplift.
  #507
Old 08-29-2018, 05:01 PM
I did a 20x24’ addition, single level. The centre beam needed a post, and that called for a 30”x30” pad, 12” thick. I doubt there would be more than 500-1000 pounds of weight on that post under normal loading.
  #508
Old 08-30-2018, 02:19 PM
They called it a monolithic slab here.
B biggest
I idot
D democrats
E ever
N nominated
  #509
Old 08-30-2018, 04:07 PM
Here if it has a thickened outer edge for a ‘footing’, it’s generally referred to as an ‘engineered’ slab.
  #510
Old 09-04-2018, 09:29 AM
Why, Hell Yes!
Tim,where are you?
