Old 02-26-2022, 09:43 PM
clive's Avatar
clive clive is offline
Default digital reader
The DRO on my lathe is not reading correctly, out by about .002” in a infeed of .020”. I suspect it needs a good clean but I have no idea what is inside it.Turning it upside down there is a cover in two halves that the reader fits between but I am reluctant to take the ends off to completely dismantle it till I know what is there and what damage I can inflict if I do it wrong.
Anyone know what is in there?
Thanks in advance.
It's So Easy
Old 02-26-2022, 10:04 PM
How far is it off in 12"?
I suspect you need to load whatever you are feeding to get a good measurement, snug up the locks and make your test, that is if you have locks.
Old 02-26-2022, 10:30 PM
clive's Avatar
GWIZ, it only does about 6”, but I found this https://www.youtube.com/watch?v=_Rs7P1SHIyM which shows what is inside so I’ll give it a good clean and see if that improves it
It's So Easy
Old 02-27-2022, 03:48 AM
clive's Avatar
took it apart, cleaned every part of it and put it back together. Still out .001” in .010” so guess it’s new reader time.
It's So Easy
Old 02-27-2022, 07:42 AM
Is it always consistent .001” off? Depending on the model of the DRO brain unit it may be able to be programmed to the change you need. Try doing a search for calibration of your unit.
Old 02-27-2022, 10:43 AM
Some DRO’s will allow a correction factor to be programmed in for things like this. Some of the older ones it was hidden away in parameters, some of the newer ones are a little easier to find.
Old 02-27-2022, 01:35 PM
My unit has internal calibration marks, you have to move the X and Y enough when powering up the machine before you start using it so it can calibrate, your might have a similar system.
Old 02-27-2022, 06:05 PM
Forgot that one, and some also have reference marks near the end.
Old 02-27-2022, 09:41 PM
clive's Avatar
Thanks for your help guys, I found the manual and it showed how to set the reference point, which I did. Then set up a dial gauge to zero, DRO to zero, then dialled on .010”. Surprise surprise, both the DRO and the dial gauge read .009”. I repeated this and got the same results each time.
Chinese lathe, about 8-9 years old so I doubt if it is leadscrew wear but could be, at least I know the DRO is functioning, I can live with that. Next I’ll check the complete length of the leadscrew. I’ll post the results.
It's So Easy
Old 02-27-2022, 10:37 PM
clive's Avatar
I just tested the thing (X axis) over the entire length of movement and it was the same. As this includes parts of the screw I have never had occasion to use I think it is shitty Chinese manufacturing techniques, maybe the one dial fits several machines and they accept this as a trade off.
It's So Easy
