![]() Some people use an oven or a toaster oven to dry rods and some people use a hot water heater to keep them warm. Has anyone ever tried a campstove to dry rods, such as a coleman? Thanks Rufus |
Rods need to be kept in a dry environment all the time. You can buy a rod oven or you can make a wooden box, line it with tin foil and put a light bulb in it.
This is especially true of a hydroscopic rod like a 7018. A coleman oven would work but you would be back to sqaure one after they sat in a wet atmospheric environment for any length of time.
Buy it cheap and stack it deep Klaatu barada nikto |
TnMike:
You gave me an idea. I was just thinking about building a box within a box and putting insulation between the two boxes and lining the inner box with foil and lining a wooden lid with foil as well and installing a lightbulb ![]() Thanks for the idea partner ![]() Rufus |
Some rods need a little moisture to work well, some don't.
http://www.rodovens.com/welding_arti...lding_rods.htm Here's a temp chart: http://www.rodovens.com/welding_arti...rage_chart.htm
USMCPOP |
And also made using just a box with the foil backed insulation board taped to the outside. I guess it depends on how fancy and presentable you want it to be. I would say a 100 watt light bulb would keep a box easily up to temperature. You may find a simple thermostat to keep it where you want it.
find a discarded Hotel fridge. Already insulated just need the heater (lightbulb)
CEC
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark - |
I have a steel bucket that sits permanetly on the wood stove in the shop that I toss all the wet rods in. Only works in the winter though.
Always one more job, but where? |
I have always wondered if an airtight container with dessicant would be enough to keep welding rods dry. I just stash my rods above the furnace in plastic bags.
It seems wasteful, at our 0.075 cents per Kilowatt/hour rate, it is 18 cents a day = ~$66 a year, to keep a 100 watt heater going 24/7 for ocassional hobby use. What about some dessicant and vacum sealing with a foodsaver? If I was to build a "home-shop" rod oven; I would use a screw-in heater element "bulb" (pet store, used for lizards) as they have a very long life. I would also use a cheap bi-metal thermostat (grainger) and super insulate the box. mark Last edited by shoprat; 06-04-2009 at 05:13 PM. |
Thankyou all for the information. There are so many options to choose from and I think I will just build a box out of wood and use aluminum foil (real thick foil) along with some insulation and a light bulb. I thought maybe a coleman stove would work for short term use (like outside the shop) since it uses no electric and burns hot. I suppose in a pinch, laying rods on the manifold of a truck would work as well.
Thanks again everybody ![]() Rufus |
