Rest In Peace Cutter
Old 05-31-2019, 11:00 AM
Default 5C expanding collets
Anyone ever use an expanding 5C collet? A 4 piece set covers 1/2" through 2".
Woodrow Wilson
Old 05-31-2019, 12:17 PM
You realize they get machined to fit the hole size of the part?
Old 05-31-2019, 02:02 PM
I did expect that. Just wondering if anyone has used them and what was their results.
Woodrow Wilson
Old 05-31-2019, 03:17 PM
We used to use them for some production stuff. Other than that, never found a use, I usually just turn a mandle in the lathe, and to make it ‘expand’ drill and tap it for a pipe thread, slit it lengthwise, and wind a pipe plug in.
Old 06-01-2019, 04:18 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
That's a neat idea. I'll have to file that away. Thank you.
Dave
Old 06-01-2019, 07:21 AM
Dave
I like that idea too! I made one before, but never thought about a pipe plug, having tapered threads would have made that so much easier.
Old 06-01-2019, 02:05 PM
Just use the closest size pipe thread for the part you are dealing with.
Old 06-01-2019, 04:14 PM
Making the slits is always the biggest problem. Should be 3 so can't just use a bandsaw . I suppose on a large one could do 4 but I've never done any big enough to do so. I've made a bunch of hex holders for "Allthread" using that same idea and the slots with a 1/16" endmill are tedious at best. :-)
...lew...
Old 06-01-2019, 06:15 PM
I always just cut a ‘plus’ across the end. Either a hacksaw, band saw, or zip cut depending on what was around.
Old 06-01-2019, 08:38 PM
mcostello's Avatar
mcostello mcostello is offline
If You run out of plumbing pats a countersunk socket head bolt will also, although the angle is steeper.
