Rest In Peace Cutter
Old 05-17-2019, 04:30 PM
Default Need refresher on tempering to harden please
Need a refresher on tempering to harden, please more of the need of hardening for stiffness
Ok so I needed to make a sort of a tool out of another tool and I heated the area of it I wanted to harden.
heated to a high red-orange and them dropped it into a huge water bucket but I did not get the results I was looking for.. "hardened with no flex or bending"... I tried to pry with it, and it still bends like soft steel what is it a am doing wrong having too many brain farts to think this out clearly...
Thanks
Old 05-17-2019, 05:48 PM
What king of tool, and what tool did you make it out of? Ifeally you would want to know the type of steel.
Old 05-17-2019, 07:14 PM
I used one of those cheap automotive door panel tools you pop door panels off with see pic below.
I needed to bend it to a hook and then intended to harden it so it would act as a pry bar in a way...
because it fits perfectly around the valve guide to pry up and off the guide seals that are stubbornly stuck to the guides.
I was going to try to use the one in the top part of the pic but that seal puller is just too large to get into the spot needed. so, I used the door panel tool under in bottom of the pic.
Old 05-17-2019, 08:33 PM
Chances are that it’s mild steel and doesn’t have enough carbon to harden it.
Old 05-17-2019, 08:56 PM
chances are that it’s mild steel and doesn’t have enough carbon to harden it.
Sent from my iphone using shopfloortalk mobile app
+1.
Woodrow Wilson
Old 05-17-2019, 09:18 PM
Camaro Zach's Avatar
I have always used channellocks to pry the old seals out. With a bit of wiggling they usually pop right out.
Buggy
Old 05-17-2019, 09:29 PM
I’m bored so here is a shot of the way I do them. Grab the seal and gently pry it up using the head as a fulcrum.
ID:	150822   Click image for larger version
Buggy
Old 05-17-2019, 10:46 PM
Randall, your looking in the wrong aisle of the hardware store. Look for a Catspaw pry bar in the carpounder section. Might have to do a little regrinding/massage on the claw. But, I think you will have what you need.https://www.bhg.com/shop/vaughan-and...f81f13631.html
Old 05-17-2019, 11:41 PM
Yeah, I've tried that ad they are stuck almost like glued on so I have tried different vise grips channel locks etc.
That will prolly do it I just didn't think about cats paw will go to town in the AM and pick up one of the small ones and grind it to shape it enough to get done with this...
Thanks Guys
Old 05-18-2019, 10:31 AM
Zach, What tool are you using to install the valve seals I borrowed one from a friend I m assuming from Summit... I have the Valve seal removal pliers but they ain't worth a shit...
So I think when I get the chance I'll just mill out my own design of removal and install tool just need o pick up some material but for ow using the cat's paw worked out much better.
