Rest In Peace Cutter
Old 05-14-2019, 05:03 PM
DENedbalek DENedbalek is offline
Default Threading challenge
Folks, I am new to the forum, well not new, but seldom if ever have posted anything. But now I'm stuck and need your advice. I have a bench grinder that came to me in a deal, but it had shaft extensions and buffing wheels on it. The original washers and nuts that you would use with a stone wheel or wire wheel are long gone.
Not a big deal I thought, just buy or make a couple of nuts. Right handed threads on the right and left handed threads on the left. I got my trusty thread gages out and lo and behold, these are 1/2 inch 12 TPI threads on the motor shaft. Again, may be easier to just buy the nuts. They are not not be found. So, I thought ok, I have a lathe why not just make the nuts. 1st problem I ran into is I don't have any 1/2" 12 TPI taps, right or left handed. So, I thought I'd single point the threads on the lathe, but I don't have any boring bars that will fit in a 27/64 inch hole (the minor dimension of the threads in the nut).
By now, this simple operation is driving me nuts. And I need the grinder if I'm to grind my own HSS bit to single point thread these nuts.
Any other ideas?
Dwayne
Old 05-14-2019, 06:06 PM
Scotts Scotts is offline
Could it be a 9/16-12 or it might be metric.
Just a thought.
Old 05-14-2019, 06:47 PM
If I was in your shoes I would buy two 7/16 "heavy" nuts and find a friend with a grinder and make your boring and threading bits, I have made both out of hss square bits. If need be cover your ways and chuck up a grinding wheel in your lathe.
Old 05-14-2019, 06:53 PM
What is the brand and model of the grinder?
Woodrow Wilson
Old 05-14-2019, 07:04 PM
Black & Decker Cat. No. 9403 Type 1.
Old 05-14-2019, 07:05 PM
I understand the making of thread cutting bits out of HSS, but I don't understand the 7/16 Heavy Nuts application.
Old 05-14-2019, 07:25 PM
They can be bored too size for 1/2 12 single point threading and take a 3/4" wrench.
Old 05-14-2019, 07:36 PM
Ah, ok. I have some some 3/4" hex stock on hand so I wasn't thinking along those lines. Thanks for the feedback though.
Old 05-14-2019, 07:52 PM
Or you could just order them.
I'm assuming you meant they're not available locally because there seems to be no shortage online.
possibly here
or here
1/2 12? Seems strange....are you sure it’s not metric?
